Browse Forums General Discussion 1 Aug 05, 2012 6:15 pm Hi all I am looking for a high pressure cleaner to clean the driveway and outdoor area, then I will seal the concrete. I found a few on eBay, not really of the quality, any comments and help will be most appreciated. Thanks in advance. http://www.ebay.com.au/itm/NEW-JetUSA-7 ... 490wt_1205 http://www.ebay.com.au/itm/NEW-JETUSA-7 ... 2573e99439 http://www.ebay.com.au/itm/NEW-3200W-35 ... 8761wt_922 Re: High pressure cleaner help 3Aug 06, 2012 9:21 am we bought the cheapest STIHL and it is brilliant, solid. we had to get a new nozzle after a few months because it didn't rotate anymore. STIHL agent replaced it without any question http://www.stihl.com.au/STIHL-Products/ ... E-108.aspx we bought it when it was on special for $299. It is worth the money and we use it a lot. Re: High pressure cleaner help 5Aug 07, 2012 8:48 pm I would recommend that you get one with a metal pump as opposed to plastic, as I believe they last much longer. I'm not sure what kind of pumps the Stihl ones have, but it shouldn't be too hard to find out. Re: High pressure cleaner help 6Apr 21, 2015 8:08 pm I am very satisfied with my cleaner. It is with metal pump and does excellent job! Laughter is what makes a home warm, and what makes a work place human Cleaning the home is a pleasure, not a burden Re: High pressure cleaner help 7Apr 21, 2015 10:11 pm The ones in an ebay add is not a direct comparison to the stihl one. The petrol models selected are going to be much more power full and can do a larger area more quickly. the cheaper ones are only good for cars etc. First time building 2 storey home, is under construction (in Framing stage) in NSW. I have 3 toilets and need bidet spray in… 0 16851 It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8265 |
