Browse Forums General Discussion 1 Aug 02, 2012 5:01 pm I'm wondering if there is any sort of program or online page that can help you get an idea of how your house will look on your land size wise? We're looking at 600m2 blocks and a 185m2 house, but I can't seem to get my head around how much room the actual house will take on the lot. Obviously there are certain rules to how many meters you need to have at the front and sides, I think 6m at the front and 2-4 on the sides, but our main concern is to make sure we have plenty of room for a pool at the back or on the side of the house (depending on sun and orientation). All I want is a simple drawing of how our 185m2 house (pretty much square in shape) will look on a 600m2 block of land! Settlement: 10.02.13 Slab: 06.03.13 Frame: 08.03.13 Lock-up: 05.04.13 Handover: 03.06.13 Build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=59555 Brisbane Photography Re: Size of house on block of land - help! 2Aug 02, 2012 8:06 pm There are a number of programs available, but i'm not up with what's around at the moment...there's probably mor than one thread here with recommendations. Whilst I'm quite capable of using design software, for a quick solution, I'd just grab a sheet of graph paper, pencil and ruler and draw up a rough sketch. I generally use 1cm=1m as my scale to make it easy. Make sure you find out what the setback requirements are for the area you're looking at, because that will make a difference to the size and shape of back/front and side yards. Re: Size of house on block of land - help! 3Aug 02, 2012 8:14 pm How long and wide is the block, and then how long and wide is your house..... You should be able to draw your own scale pic to work out the distance from the house to the rear boundary. My builder did that for me at our first meeting before i had even committed 2 Re: Size of house on block of land - help! 4Aug 02, 2012 8:36 pm MalinViktoria I'm wondering if there is any sort of program or online page that can help you get an idea of how your house will look on your land size wise? We're looking at 600m2 blocks and a 185m2 house, but I can't seem to get my head around how much room the actual house will take on the lot. Obviously there are certain rules to how many meters you need to have at the front and sides, I think 6m at the front and 2-4 on the sides, but our main concern is to make sure we have plenty of room for a pool at the back or on the side of the house (depending on sun and orientation). All I want is a simple drawing of how our 185m2 house (pretty much square in shape) will look on a 600m2 block of land! 1.15m required on one side, garage can be built to the boundary. 4-5m or more from the front. But will vary depending on council/state requirements, I'm in Victoria. 185m^2 isn't that big, also its going to vary depend on how wide your house is. If you leave the minimum room on the side you could make an estimate of how much land you will be taking, or how much backgarden you will have in the best case... Re: Size of house on block of land - help! 5Aug 02, 2012 8:42 pm Thanks guys! If I have a spare moment, I will do the pen and paper thing, but I'd much prefer a program to do it more accurately. ETA: Okay, this is my rough attempt in photoshop, I don't know how accurate it is though. Does this look like a 185m2 house on a 600m2 lot to you?? *lol* I hope so. Settlement: 10.02.13 Slab: 06.03.13 Frame: 08.03.13 Lock-up: 05.04.13 Handover: 03.06.13 Build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=59555 Brisbane Photography Re: Size of house on block of land - help! 6Aug 02, 2012 11:03 pm Google sketchup works a treat! and it is free Where you are coming from is where you are going to... Re: Size of house on block of land - help! 7Aug 02, 2012 11:14 pm Where you are coming from is where you are going to... Re: Size of house on block of land - help! 8Aug 02, 2012 11:38 pm My house is 186sqm (total 245sqm if you include garage and alfresco) on a 433sqm corner block. It's as close to the front as allowed, has around 1.5m on the sides and the backyard is about 4.5m long and 15m wide. The alfresco part is 8.5m long. I'm thinking you will have more than enough space for a pool. GOODLIFE - Bravo - BUTLER http://getmistyfied.blogspot.com.au Display 20/02/2012 PPA 01/04/12 Prestart: 25/07/12 Settlement: 31/07/2012 Contracts:August Slab 19/11/12 BRICKS 10/11/12 Roof 16/01/13 Re: Size of house on block of land - help! 9Aug 02, 2012 11:45 pm Like above? That was a very quick sketchup 10 x 18.5mtrs on 20 x 30mtrs Where you are coming from is where you are going to... Re: Size of house on block of land - help! 10Aug 03, 2012 1:16 am another one that is very easy to use is sweet home 3d. not as detailed as google sketchup as it does not have roof but I think it is much easier to use..... check it out its free.... Re: Size of house on block of land - help! 11Aug 03, 2012 1:41 am SH3d is more for interior stuff but fine if that's what you want Where you are coming from is where you are going to... Re: Size of house on block of land - help! 13Aug 03, 2012 9:23 pm Having read your previous posts I'd think very carefully about that house layout. It's basically going to be an apartment with the noise - no hallways, so no double walls anywhere, and didn't you mention kids being in the long-term picture? More importantly I'd question given the three estates you've talked about looking at, where are you going to find a 600m^2 block within the budget you've talked about? You're typically going to have a block designed for a certain width house (or vice-versa), so the house isn't to sit in the middle of a square. ie, you're not likely going to have space down the right side of that diagram, instead, the block would be deeper. A standard block width is going to be 16m x 37.5m deep for 600m^2 dimensions - ie, you'd have a 1200mm(ish) path down the left side. Most estates these days require all houses to have the same setback within a certain measurement, so if everyone has already built to 3m setback, you'll have more backyard; if everyone else is at say 10m, you might have a tiny back yard. You need to decide whether you want a big square back yard, or a narrow, deep back yard. Building a Delta 21 at Craigieburn - http://homeofzero.blogspot.com.au/ Deposit: 26/02. Contract: 22/05. Settlement: 29/05. Site start: 18/10. Re: Size of house on block of land - help! 14Aug 04, 2012 1:40 pm akashra Having read your previous posts I'd think very carefully about that house layout. It's basically going to be an apartment with the noise - no hallways, so no double walls anywhere, and didn't you mention kids being in the long-term picture? More importantly I'd question given the three estates you've talked about looking at, where are you going to find a 600m^2 block within the budget you've talked about? You're typically going to have a block designed for a certain width house (or vice-versa), so the house isn't to sit in the middle of a square. ie, you're not likely going to have space down the right side of that diagram, instead, the block would be deeper. A standard block width is going to be 16m x 37.5m deep for 600m^2 dimensions - ie, you'd have a 1200mm(ish) path down the left side. Most estates these days require all houses to have the same setback within a certain measurement, so if everyone has already built to 3m setback, you'll have more backyard; if everyone else is at say 10m, you might have a tiny back yard. You need to decide whether you want a big square back yard, or a narrow, deep back yard. I don't see the layout being a problem. even with kids in the future. We are on a tight budget, and we don't really need more than this. Also, we've already found a few 600-700m2 blocks of land from $125k that we're considering, so that's also not a problem. I already mentioned in my original post that they do have a 6m at the front rule, and 2-3 meters on the sides, which isn't a problem for us. We WANT a lot of a space around our house because we want to put in a pool at some stage (also mentioned in the OP), and we'd like a dog or two at some stage and have room for them to frolic in the backyard, as well was play space for future kidlets. @kek: I downloaded the program you mentioned, but it never stopped updating so I couldn't use it. Trying Google Sketch-up next! Settlement: 10.02.13 Slab: 06.03.13 Frame: 08.03.13 Lock-up: 05.04.13 Handover: 03.06.13 Build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=59555 Brisbane Photography Re: Size of house on block of land - help! 15Aug 04, 2012 3:23 pm do the tutorial you will get the hang of things if you try stuff scroll button = zoom in/out click and drag or click start and enter measurements and it will auto shape edit/undo, push/pull = stamp, lots of shadow checks but they are in reverse (ie opposite seasons[swap dec for june]) . Easy for me I've been using it for more than a few years. Time consuming though but at what cost to roughly shape design a house? particularly as 'one' would design to the block of choice not design a house and find a block that suits. sorry for the rant Good luck there are a few links somewhere here Where you are coming from is where you are going to... Re: Size of house on block of land - help! 16Aug 14, 2012 3:32 pm Okay, I finally managed to do it up in Google Sketch-up. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ However, we've moved on to considering bigger houses, such as these ones. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We're also considering larger blocks for the bigger houses. But it helped a lot to see them like this! Settlement: 10.02.13 Slab: 06.03.13 Frame: 08.03.13 Lock-up: 05.04.13 Handover: 03.06.13 Build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=59555 Brisbane Photography Re: Size of house on block of land - help! 17Aug 14, 2012 9:24 pm Considered the Arena 4.1 or Avant 4? They might work better with what you're trying to achieve in the same price range and in terms of features. Building a Delta 21 at Craigieburn - http://homeofzero.blogspot.com.au/ Deposit: 26/02. Contract: 22/05. Settlement: 29/05. Site start: 18/10. Re: Size of house on block of land - help! 18Aug 18, 2012 9:24 pm akashra Considered the Arena 4.1 or Avant 4? They might work better with what you're trying to achieve in the same price range and in terms of features. By which builder? Settlement: 10.02.13 Slab: 06.03.13 Frame: 08.03.13 Lock-up: 05.04.13 Handover: 03.06.13 Build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=59555 Brisbane Photography 1 1929 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7544 |
