Browse Forums General Discussion 1 Jul 20, 2012 4:35 pm Hi, Not sure whether this is the right forum as there doesn't seem to be a plumbing electrical one. Anyway, I want to hang a couple of things and I am not sure where the water pipes are and just wondering if anyone can assist in how to locate them. I know there is a particular gadget you can buy from Bunnings etc called a stud finder or something. But as I have a brick wall I am not sure whether this would work. Also I do not want to spend a fortune as it will only be used a couple of times, but may come in handy for the new build. Any suggestions, brands etc that I can buy? It would also be handy if this was able to locate electrical too. Thanks in advance.. Slab Poured 30/05/12 Lower Floor Plate High 20/08/12 Upper Floor & Wall Framing 30/08/12 Roof 14/09/12 Lock-Up 13/12/12 Yee haaaaa WE ARE IN & I HAVE A NEW IPHONE Re: PLUMBERS.....HELP HOW TO LOCATE WATER PIPES IN BRICK WAL 2Jul 23, 2012 4:30 pm What exactly do you want to hang? A standard metric house brick measures 230mm long x 1100mm tall x 76mm wide. This means you'll have to drill 76mm+ before you hit the other side. I doubt (although it may happen for some unknown reason) that anyone would feed a water pipe trough a single brick wall. If so you have no way of finding it IMO. However, if you're talking about hanging shelves, you can use Dynabolts or a chemical anchor that does not require you to drill through the brick and out the other side. If its just for pictures then you can use those expanding plastic sleeve type plugs that you drill into the mortar and secure with an oversize screw. Stud finders are designed to find timber studs hard up against plasterboard sheeting and even foil insulation can interrupt expensive ones. I know, because mines not cheap and it doesn't work on my garage wall, garage side where the foil wrap is. You can get yourself a good Stanley stud finder from Bunnings for $15. Handy to have and pretty cheap too. Re: PLUMBERS.....HELP HOW TO LOCATE WATER PIPES IN BRICK WAL 3Jul 23, 2012 5:27 pm If you can run hot water through I could find it for you with thermal imaging but visit plus inspection and report is $ 450.00 and that is probably lot more than you want to pay. I don't have cheap alternative for you Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: PLUMBERS.....HELP HOW TO LOCATE WATER PIPES IN BRICK WAL 4Jul 23, 2012 6:53 pm The wall is an internal brick wall and therefore has NO cavity...The pipes were chased into the wall and plastered over. This is how builders do things in the West.... I wanted to hang a picture, but doesnt look like its possible then Slab Poured 30/05/12 Lower Floor Plate High 20/08/12 Upper Floor & Wall Framing 30/08/12 Roof 14/09/12 Lock-Up 13/12/12 Yee haaaaa WE ARE IN & I HAVE A NEW IPHONE Re: PLUMBERS.....HELP HOW TO LOCATE WATER PIPES IN BRICK WAL 5Jul 23, 2012 8:36 pm What wall is it? Is it in a bathroom? Or just a random wall in the house? If it's into plaster over brick, this is a bit of stuffing around. Mark where you want to put the fixing, then just below and too one side cut a hole in the plaster. Check there are no pipes then patch the small holes and put your fixings where you want them to go. Re: PLUMBERS.....HELP HOW TO LOCATE WATER PIPES IN BRICK WAL 6Jul 23, 2012 11:21 pm Oneness. Where are the holes you are going to put in and what sort of fixings are you wanting to use? If they are in a bedroom or living area then you will be fine, just don't drill directly above a power point as the cable is chased straight up the wall from power points. Even if the wall backs onto a bathroom you would need to have drilled almost through the wall before you'd hit a pipe If you are drilling in a wet area then the pipes are usually run in fairly standard positions however with the advent of PEX pipes the routing of pipes can be a little more random than it used to be with copper. Any chance you can put a picture up and I'll let you know if you'd need to be concerned. Just realised that it is a picture you want to hang. Just go to Bunnings and get some 5mmx25mm mushroom head Ramset nylon anchors and some Ramset wall hooks. That's the simplest way to hang a picture. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: PLUMBERS.....HELP HOW TO LOCATE WATER PIPES IN BRICK WAL 7Jul 24, 2012 12:33 am Hi Chippy, yes I use the Ramset for all the pictures/mirrors I hand. Just concerned that this one is in the bathroom above the taps/spout and dont want to drill and hit a water pipe as the white set plaster and green render are not very thick... Beginning to just give up on the idea and use the wall stickers for art instead! Slab Poured 30/05/12 Lower Floor Plate High 20/08/12 Upper Floor & Wall Framing 30/08/12 Roof 14/09/12 Lock-Up 13/12/12 Yee haaaaa WE ARE IN & I HAVE A NEW IPHONE Re: PLUMBERS.....HELP HOW TO LOCATE WATER PIPES IN BRICK WAL 8Jul 24, 2012 6:10 am oneness The wall is an internal brick wall and therefore has NO cavity...The pipes were chased into the wall and plastered over. This is how builders do things in the West.... I wanted to hang a picture, but doesnt look like its possible then What about renting a metal detector ? This should be able to pinpoint the general area. Re: PLUMBERS.....HELP HOW TO LOCATE WATER PIPES IN BRICK WAL 9Jul 24, 2012 9:33 am If it's above your basin then you should be fine. Plumbers typically run all the pipes together and not in areas that are likely to have the need for holes to be drilled. They avoid putting pipes where mirrors and shower screens will be installed. Usually the pipes come down into the bathroom in the shower recess area and then after going to the shower taps, run horizontally to the bath and basin. If you are really concerned just get up in the roof and see if there are any plumbing pipes running into the wall directly above where you want to drill. Pipes run either vertically or horizontally they dont just run them in random directions. If there is no pipe showing in the roof area where you want to drill then you will be fine. Can you post a picture indicating where the hole is to go. I'll tell you straight away if you need to be concerned. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: PLUMBERS.....HELP HOW TO LOCATE WATER PIPES IN BRICK WAL 10Jul 24, 2012 10:37 am Chippy is reasonably correct. I had this problem a few years ago when fixing grab rails for the oldies and they had to be near the taps for obvious reasons. Never hit a pipe (being a tradie I had an idea where the pipework ran) although the oxy set was always in the van just in case. LOL Why you want to hang a picture in a wet area escapes me as I think steam would eventually ruin it, however if its a heavier mirror I would NOT use stick on hooks as they occasionally let go Arfur Re: PLUMBERS.....HELP HOW TO LOCATE WATER PIPES IN BRICK WAL 11Jul 24, 2012 12:05 pm Lourance If you are really concerned just get up in the roof and see if there are any plumbing pipes running into the wall directly above where you want to drill. Pipes run either vertically or horizontally they dont just run them in random directions. If there is no pipe showing in the roof area where you want to drill then you will be fine. I think getting up in the roof is a good idea... It is above the end of the bath which is located next to a window...I had thought perhaps the pipes would come in horizontally from the cavity..If they are vertical then I am screwed as the hook would be smack in in the middle. chippy Why you want to hang a picture in a wet area escapes me as I think steam would eventually ruin it, however if its a heavier mirror I would NOT use stick on hooks as they occasionally let go I know what you mean but this is a bathroom that only ever gets used when I feel like having a bath (it is the spare bathroom)..Just wanted to brighten it up before selling...I would never use sticky hooks either...would not take the risk... I will be sure to take photos of all pipework/cables etc in the new build for future reference Thanks everyone for all your input too!! Slab Poured 30/05/12 Lower Floor Plate High 20/08/12 Upper Floor & Wall Framing 30/08/12 Roof 14/09/12 Lock-Up 13/12/12 Yee haaaaa WE ARE IN & I HAVE A NEW IPHONE Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 10805 4 5099 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5704 |
