Browse Forums General Discussion 1 Jul 15, 2012 11:12 pm Can someone suggest the place you can get fish tank in Perth? Looking at wall mounted fish tank that can go in the recess wall. Found one place but interested in seeing some other options. Mind you, we never had a fish tank, so we thought the idea would be nice... Re: Fish Tank in Perth 2Jul 16, 2012 10:26 am hi, not sure about tanks over there... but have you thought of what type of aquarium you are thinking of? as a marine / saltwater tank will cost you $$$ and generally a huge amount of time and money to upkeep. Re: Fish Tank in Perth 3Jul 16, 2012 10:41 am Although I am from Perth I live in Singapore and keep tropical fish. I think all the tanks that are installed as in-wall separators need a lot of upkeep. My tank in Singapore is a 600L tank with 80L sump filter and it is still quite a bit of work. I have a big water filter to remove chlorine but if you are using tap water you will need to condition the water. There is an aquarirum shop at the end of Grand Prominade and Railway Parade in Melthem (near Maylands) its called aquarium city. I would not try a salt water tank as a beginner unless you are paying someone to maintain. Tropicals are also quite expensive in Perth. If you are serious, PM me and I can give you a cost comparison as the price diff will pay for a holiday in Singapore. My set up in Singapore is about AUD1,000 and in Australia it would be double if not triple that I think. Although it is a lot of effort it can be quite rewarding (and frustrating) sometimes. Cheers Mark Re: Fish Tank in Perth 5Jul 16, 2012 11:07 am I kept 11 tropical tanks in my nuttiest moments. I'm now down to one 6ft tank and two nano tanks. If you are seriously considering investing in an in-wall tank, and it's your first time keeping tropical fish, I highly recommend aquariumlife.com.au. It's an Aussie fishkeeping forum, with quite a strong WA presence. They will be able to give you all the advice you need,including recommendations for tank builders - but be warned. It's a steep learning curve early on! Building the Denver by Metricon on acreage Land settlement: 24/8/15 Contracts: 8/7/16 Finance approved: 5/8/16 Council approval.....? viewtopic.php?f=31&t=79213 Re: Fish Tank in Perth 6Jul 16, 2012 8:58 pm Thanks everyone for suggestions. I wasn't thinking about getting salt water tank, I was thinking about normal "tap/river" water tank and fish to go with it. I honestly don't know anything about the fish i must admit, just wanted something "nice" to look at... I guess I'm just like one girl that came to HiFi store (true story) and said that she wanted to get silver HiFi system regardless how much it cost or what functions it has simply because it was going well with her decore. Re: Fish Tank in Perth 7Jul 16, 2012 9:24 pm LOL, no dramas, hey aquariums are ALL about the visual aspect, so dont blame you so in that case, forget a cold water tank you will want a tropical tank, you can get a good variety of fish/colour, and setup I have seen some awesome tropical tanks done they are ok to maintain, just do your research and away you go. not overly expensive to setup or maintain.... show us a pic once you have done it Re: Fish Tank in Perth 8Jul 23, 2012 11:18 am Hey there tengals is definitely spot on forget about the cold water tank. You can setup a nice tropical tank within budget and make it low maintenance. There's so many ways of doing it. You should be able to source cheap parts from forums as well. More than happy to assist. Re: Fish Tank in Perth 9Jul 24, 2012 1:14 pm I had a salt water tank to much time to look after it. Go tropical, Ebay sometime has some good bargains.. Re: Fish Tank in Perth 11Jul 24, 2012 7:42 pm You don't. Sand is horrible to keep clean. You can only hold the vacuum a couple of centimetres above the surface - just enough to suck up the surface debris but little to none of the sand. Gravel/aquarium soils are much easier. Sand in marine tanks needs to be turned over to prevent anaerobic pockets releasing poisonous nitrogen gasses. There are ways to keep Deep Sand Beds, but they are a whole other lesson. Easiest to keep them under a couple of inches deep and just turn over frequently. Building the Denver by Metricon on acreage Land settlement: 24/8/15 Contracts: 8/7/16 Finance approved: 5/8/16 Council approval.....? viewtopic.php?f=31&t=79213 Re: Fish Tank in Perth 12Jul 25, 2012 11:47 am Bubblynutter glad to see you here as well as AquariumLife if you are the right person? I had white sand and it's very difficult to keep clean. I would go for a dark gravel as it doesn't look too dirty and easy to suck up the debris with a vacuum. Re: Fish Tank in Perth 13Jul 25, 2012 5:19 pm The very same. Building the Denver by Metricon on acreage Land settlement: 24/8/15 Contracts: 8/7/16 Finance approved: 5/8/16 Council approval.....? viewtopic.php?f=31&t=79213 Re: Fish Tank in Perth 14Aug 04, 2012 11:52 pm Very late in replying to this thread but anyway....... Another thing you can do that I think makes a tank visually stimulating is to have a planted tank. And use aquarium soil instead of sand or gravel Also helps keep your tank a little healthier by removing some of the fish byproducts naturally with the plants absorbing them. But it depends on what look your after. I personally love a plated tank and spent more time organizing the plants than the fish lol Now I spend hours watching the whole tank very therapeutic. And I love my little shrimpies And always get the best filter you can afford. Cheers Janet Thanks for letting us know. The programmer will have a look at this later today. 2 6809 DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31409 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17641 |
