Browse Forums General Discussion Extension Cost Per Square Metre - are builders serious! 2Jul 10, 2012 5:41 pm My Knock down and Rebuild thread viewtopic.php?f=31&t=54685 Our Building Blog http://ourknockdownrebuild.blogspot.com.au/ Re: Extension Cost Per Square Metre - are builders serious! 15Aug 11, 2014 10:51 am chrisandkate its hard to see why a builder wants $2500m2 to do basic extension when you can get a basic/budget house for less than $1000m2 if you only get base level fittings. I'd guess the OP lives in a well heeled area. When thats the case, expect quotes to be double in comparison to what they would be in a working class suburb. In 2005 I lived in such a suburb, and been quoted 250K to do such a reno as the Op's, when a new house of similar total size would have cost $170K (at the time) To do it myself as an OB it would have cost about $60K. After I disseminated one builders quote, I worked out he wanted $1500 a day in labour. Pffft. chrisandkate they do it because you can charge a Sh1tl0ad of money from unsuspecting people. Exactly. joeygbh The higher cost of renovations actually has to do with risk. The builder does not know what they are working with, and so has to add a risk premium in case their work damages the existing one though no fault of their own. I dont buy that at all. A house is either stable, or not. An extension will strengthen the house, if anything. joeygbh They have to do a lot of work to stabilise the existing house and can't work the way they want to to maximise efficiency. PLease elaborate on this stabilising you are talking about, because Ive seen an extension done next door onto a pre war colonial, and I watched it being built day to day. And there was no stabilising done. Rear wall removed, and extension just tacked right on to existing. joeygbh When you knock down and rebuild the slate is clean, you can do all your slab in one day, trusses next, painting etc, which is much more efficient and hence cheaper. True, but you are only talking about the efficieny around one wall (the wall that the extension is being attached to), and I would say its a moot point that is is much less efficient. In any case, normal efficiencies to the other sides of the extension should still apply. I dont see anything in your answer at all that justifies a doubling or tripling of price. Hi Has anyone recently completed an extension in Melbourne. Any idea at what I'd be looking at for an extension of our living room (adding 4mx5m). 0 7784 Seems good to me. I've been told $4-5k/sqm is reasonable in Perth. 2 11171 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 3597 |
