Browse Forums General Discussion Re: Are in-wall cisterns noisy for adjacent room? 9Jul 10, 2012 5:56 am How often would you be using both rooms simultaneously? If people are in the home theatre room watching a movie, is there going to be a constant flow (excuse the pun - I could have said "steady stream"!) of people using the powder room throughout the duration of the movie? I live in a two person household, so for me it wouldn't be an issue at all - but even if you have a number of residents, couldn't you just make it a "rule" that the powder room toilet is not used when the theatre room is being used? After all, you will have another two toilets upstairs (ensuite and main). I understand that you are planning for all eventualities now while you can, but it might just need a behavioural solution rather than a design solution/compromise. We are building a second dwelling and are currently selecting window and door frames. We want to blend into the forest and also bring out the stone work and the fake wood… 0 15933 18 90484 Hi, I have a double and whenever the wind picks up I can hear alot of banging in certain areas of the house. I've had a look round and can't see any obvious issue but… 0 10646 |
