Browse Forums General Discussion 1 Jul 04, 2012 8:24 pm I just built a house its a year old today i have a issue with my floor tiles when they were layed they were perfectly level now they have seemed to of lifted in some places alot more than other areas is it a sign of the slab shiffting/ sinking theres no cracks on walls or tiles and there doest seem to be any crackes loose or missing grout anywhere i now for a fact the tile layer used correct glue and sufficient amounr is there any way i can check or get someone to check if my slabs ok or is it another issue Re: Floor tiles 2Jul 04, 2012 9:40 pm Use a key or coin and tap on the tile you think has lifted, it will make a hollow sound if the glue has let go. If there is no crack in the grout and the tile is not drummy I tend to think it was like that from day one. Re: Floor tiles 3Jul 05, 2012 9:11 pm I layed the tiles so i used sufficent amount of glue its not just one tile thats my concern some areas in the hallway its 3-4 in a row and various other places around the house its more than one tile and the part that confuses me is that they havnt cracked or missing grout They make the room much easier to clean for one, reflect more light (if light colour tiles are used), and you dont end up with dust on the top edge of tiles (cause most… 3 9618 To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 419 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16567 |
