Browse Forums General Discussion 1 Jul 02, 2012 8:54 pm I have a septic system that has a high water alarm which consists of a float and a LED light which flashes if the pump fails and the water level gets too high. My problem is that the light flashes once every two minutes. It is doing this even after both the float and the light have been replaced. The pump is working perfectly and the water level is no where near the float level. Would anyone have any idea why it is doing this - it is baffling both my plumber and my electrician. I know this post is from a while ago, but the VBA has some good guidance on this. https://www.vba.vic.gov.au/__data/asset ... 5-Roof.pdf 2 10619 AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6271 Building Standards; Getting It Right! There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have… 1 10128 |
