Browse Forums General Discussion 1 Jun 27, 2012 8:20 pm I'm looking to remove old bedroom wardrobe doors and replace with new ones with a more modern finish - high gloss white, or something similar. All the hinges and wardrobe structure will remain as is, so I'll use the existing doors as a template. Does anyone know where I can source modern bedroom wardrobe doors and have them cut to size based on the old ones? I live in South East/Bayside Melbourne. Any help would be most appreciated. Re: Bedroom wardrobe doors 2Jun 27, 2012 9:34 pm turns71 I'm looking to remove old bedroom wardrobe doors and replace with new ones with a more modern finish - high gloss white, or something similar. All the hinges and wardrobe structure will remain as is, so I'll use the existing doors as a template. Does anyone know where I can source modern bedroom wardrobe doors and have them cut to size based on the old ones? I live in South East/Bayside Melbourne. Any help would be most appreciated. go to sites like corinthian doors or hume doors and check for local suppliers. they could probably arrange to do any of their door styles in a hollow fitout for a wardrobe door. It's an idea ..... not sure if it will work .... 2010, June : Land bought (1700sqm, battleaxe block). That's it so far! We're in the design phase .... Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the… 3 3075 Probably a not bad thing to mention particle board should in case anyone else reading this got the two confused. 6 4906 Personally, considering your layout (study/work desks in bedrooms), I don't think you have any other option but to leave NW windows and make them as big as possible e.g.… 7 10483 |
