Browse Forums General Discussion 1 May 21, 2012 11:14 am Just after some advice in regards to a house that was built by a popular building company and the cracks that are starting to appear, little holes in bath tub which is leaking out into the bedroom here is some pictures... We have had somemuch trouble with them, I am just sick of being passed around.... http://s1261.photobucket.com/albums/ii600/nay131313/ are some of these requests reasonable Re: needing advice 2 years after home was built maintenance 2May 21, 2012 2:10 pm Is the builder refusing to repair them? Arfur Re: needing advice 2 years after home was built maintenance 3May 21, 2012 6:10 pm Hi naytahlia, The cornice cracking is common and does not look too bad. Even if you want to chase a builder they will refuse to patch a cornice crack on the corner. If they did finally come around to fixing it, all they will do is plaster it up which will only crack at a later stage. You are better of heading down to the local hardware store and buying white flexible sealant and doing it yourself. On the other hand, the leaking bathtub is serious. I would avoid using bath tub for starters until it is fixed. The builder will tend to fob you off but if you whinge loudly and complain and say that you cannot use the bath for your children (you can lie there), then hopefully they will listen. If not, you might have to bite the bullet and get someone to recaulk the area. All the best. Joe, it depends on your certifier but we are noticing the ones we deal with are really cracking down. So i would recommend you follow your approved landscaping plans to… 4 10972 DIY, Home Maintenance & Repair We purchased a 1960s property that is on timber stumps mostly, and a newer section is on concrete stumps. We had a building inspection initially and they reported some… 0 12743 Hi All, we are starting to think of building with Masterpiece Builders in Victoria, has anyone had any feedback or experience with them 0 13588 |
