Browse Forums General Discussion 1 May 17, 2012 8:11 pm Hi All Looking for some guideance if possible. We have a water coming into our subfloor pooling against the retaining wall to the lower level. I was sure it was a watercourse as we had rain and it seemed to rise when we had rain, however we have had no rain for weeks and it is still coming in at the same rate, I remove around a bathtub full daily with a sump pump. I am now starting to think the watermain or the hydrant at the front of the property nature strip has a leak, We are in the Brisbane City Council area but I am unsure who maintains this infrastructure. Also how can we tell where the water is coming from? it is only a matter of time before it will create structual problems so any advice would be appreciated. Cheers Chris Re: Water Leak 2May 17, 2012 9:15 pm If you think its a water main or hydrant contact Queensland Urban Utilities http://www.urbanutilities.com.au/ The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. If you make sure all taps inside and out are turned off, what does the water meter show if you leave it for a while. 2 20235 Hi all, I am hoping someone has some ideas as to what is causing my bathroom leak. The leaking appears to mainly happen when we turn the sink basins on. It takes a while… 0 5084 DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 17323 |
