Browse Forums General Discussion 1 May 15, 2012 10:54 pm Hi all, We recently converted our roof space to an attic and need to install lighting. We came across these battery powered motion sensor LED's on the Mr Beams Australia website that look like a good idea. Has anyone used them? Regards Pat Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28812 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8814 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8572 |
