Browse Forums General Discussion 1 May 02, 2012 2:46 pm I am about to do some minor outdoor renovations using Hebel / AAC blocks. This will include outdoor seating, garden edging and fence pillars. Anyone got advice or comments on using these blocks? And would I need to water proof the blocks where a garden will be behind it? Thanks Ray Re: Hebel / AAC 2May 02, 2012 3:51 pm If you are using blocks as a retaining wall you will need to make sure it is properly designed. You will need to put drainage behind it and waterproof it The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Hebel / AAC 3May 02, 2012 10:11 pm The hebel product is not great those applications, its strenghts are its weight and fire resistance etc. Why not humble concrete block, it's like me, cheap and cheerful!! @builderforlife Building inspector and passionate about construction When you need an expert to take a look. Re: Hebel / AAC 4May 03, 2012 12:43 pm My only concern with concrete block was the footings and infill. What footings would I require for pillars for a front (1200mm high) fence and a small (400mm high) garden wall. Also, do you need to fill the concrete block with concrete or can the voids be left as is? Thanks Ray Re: Hebel / AAC 5May 03, 2012 4:54 pm With block work (including Hebel) retaining walls you always need a good foundation. I would recommend you go and borrow a library book that includes something about building blockwork walls. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Hebel / AAC 6May 03, 2012 5:12 pm If your wall or retaining wall is more than 1M high you will need building permit Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog I was looking at different options for a fence for my build and Hebel PowerFence seemed like a good option (one of the criteria was a solid wall look). However, I don't… 0 5881 1 6602 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6174 |
