Browse Forums General Discussion 1 Apr 04, 2012 4:19 pm We are looking at extending our current Steel framed house. Not sure if we should continue with steel or complete it with Timber? Not too many builders touch steel where we live and builders are busy to even quote! An unbias opinion would be very helpful. Thanks Re: Extensions with Steel or Timber? 2Apr 04, 2012 10:24 pm I wouldn't consider using steel for a timber house extension. Therefore I'd go with steel if it has a steel frame already. Getting quotes is a pain no matter what materials you want to use. Good luck Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14442 This is 100% true. You can not hang anything on steel frames. very frustrating 8 8021 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15908 |
