Browse Forums General Discussion 1 Mar 01, 2012 6:23 am We are building a new house on a sloping block and are at lock-up stage. We have just noticed that the water is seeping (actually leaking) through the slab in the middle of the house. No drain pipes or aggi drains have been installed yet. We have hihglighted to the builder in previous occasions that there is lot of water clogging at the backof the hosue everytime it rains. Builder says that this water seepage will go away once the aggi drains and downpipes are installed. My query is 1. is he correct, do we need to do anything else 2. will this water seepage cause any damage to the concrete slab on this sloping block. Please share your thoughts Re: Water seeping through slab in a new house 3Mar 01, 2012 8:18 am humble If there is water runing under the slab, over time, that would cause considerable damage I Would suspect. Especially if the water is trapped betwee the concrete and the black plastic Re: Water seeping through slab in a new house 4Mar 01, 2012 9:37 am I would be installing agri and stormwater drains ASAP as I dont think you will be able to move in under these conditions. Once your drains are installed any water trapped under the house will soak away with time Arfur Re: Water seeping through slab in a new house 5Mar 01, 2012 1:36 pm That sounds like typical builder BS. He should have installed the drainage at the start, and I bet you'll find the contract says he's responsible for keeping the site adequately drained all through the construction. Metricon Riva 33 - http://herlihy-riva.blogspot.com Site start 15/03/2010 - Handover 23/12/2010 9 months and 8 days (284 calendar days) from site start to handover Re: Water seeping through slab in a new house 6Mar 01, 2012 3:41 pm Thanks guys for the replies. Buildeer is supposed to install aggi drains as per contract which he says he would do after the scaffholding has come down. Is there anything else I can do to prevent further damage after from the preventative ones of installing drain pipes. Is there a way to assess how much damage it has already caused, if any. Re: Water seeping through slab in a new house 7Mar 02, 2012 12:45 am Hey Guys, I’ve got a similar problem. We moved in 4months ago and have always notice water patches at the front of our home even on 35degrees plus days. We have had the builder’s plumber come out three separate times now and they dug up the soil and told us they can’t find the leak. A leak guy came out and said it is coming from under the slab and that’s it. They told us not to worry as the water meter is not moving so we are not getting charged for it. Today we just had our three month maintenance and in the hallway the skirting boards are slowly coming off the walls. The guy told me it’s would be caused from a water leak from under the bath and that he will arrange for a plumber to come out ASAP. I had a look at the meter and work out the meter is moving about four numbers every hour. (I shouldn’t have trusted the tradies) So we have been paying for wasted water for over 4months and what I am most worried about is all that water which is leaking under the slab and now slowly leaking into the house. What damage would this of cause over this time? I had a closer look at the skirting boards today and the plaster above it and in some spot it is quite damp. Any advice would be great Cheers Luke Re: Water seeping through slab in a new house 8Mar 02, 2012 6:50 am You need to talk with the builder and potentially get an independant inspection done. It is the builders problem so they must organise fix. Document everything, take photo's and if possible comminicate all these issues via email so that you have record. Re: Water seeping through slab in a new house 9Mar 02, 2012 11:41 am luke, i am meeting with my building surveyor soon to discuss the problem of water leaking under tha slab. Will let you know of the outcomes. as someone else has mentioned, document everything and put it in writing - even if it is repeating what you have already discussed with the builder. most of them are like cow boys with no regard for owners investment. Re: Water seeping through slab in a new house 10Mar 05, 2012 6:21 pm I met the surveyor today and he is going to ask the builder to provide an engineers report on the water leakage. he says that the water can eiher come from under the slab which is the ground moisture or from the sides which is the rain water seeping through as there are no drains installed. He will ask the builder to provide an engineers report. Re: Water seeping through slab in a new house 12Mar 06, 2012 12:16 am Hi Guys .. best product to stop the water migration is a product called Moisture fix from Protect Crete in Melbourne .. simply broom on to apply . It will react within the concrete and form a barrier to prevent hydrostatic and your issue .. it is also used to control moisture for Vinyl etc ......... Re: Water seeping through slab in a new house 13Mar 06, 2012 6:30 pm getnewlookjason Hi Guys .. best product to stop the water migration is a product called Moisture fix from Protect Crete in Melbourne .. simply broom on to apply . It will react within the concrete and form a barrier to prevent hydrostatic and your issue .. it is also used to control moisture for Vinyl etc ......... thanks getnewlookjason is it only applied in the inside of the house or it also applied on the outisde of the slab. is there a risk if the moisture barrier is damaged causing the water to leak in Re: Water seeping through slab in a new house 14Mar 08, 2012 12:22 am Hey Guys, The plumber came over the other day to check out a water leak problem. He cut a hole in our wall from the hallway to see under the bath in our bath room. He told me he can’t find the leak but will come back again with a leak guy. He said they will have to put compressed air into the water pipes and where the leak in the pipe it will whistle. Then they know exactly where the leak is. He put the plaster board cut out back in the wall and taped it up before he left. Then I decided to have a look and there is water everywhere under the bath tub, I can see the frame starting to rot in some spots and on the skirting board. I am not sure what to do here. Should I tell the builder to re-do our frame in the bath room? Or some how strengthen it? We will need new skirting boards and even some of the plaster re-done from water damage. Will let you know more next week they come back to fix the leak. Luke Re: Water seeping through slab in a new house 15Mar 14, 2012 5:56 am luke11 Hey Guys, I am not sure what to do here. Should I tell the builder to re-do our frame in the bath room? Or some how strengthen it? We will need new skirting boards and even some of the plaster re-done from water damage. Luke I think you should get an independent assessor to have a look at get his opinion. This would help you to know where you stand with reference Building Commission's guidelines. Re: Water seeping through slab in a new house 16Mar 14, 2012 12:35 pm Problem has now been fixed!! The water leak was coming from the HWS as there was a broken pipe. The water under our bath was a second issue, they believed the water build up under the bath as before we moved in there was a sewage problem. So they drain out the water from under the bath (using a paper cup) and said the remaining water will dry in time. The water meter is not moving four number an hour now which is good. Will have to contact the builder now to find out what they are going to do about the rotten frame and skirting board. Re: Water seeping through slab in a new house 17Mar 16, 2012 9:08 pm I would be extremely concerned about foundation damage and it is more than likely that the builder is not following soil test report recommendations for drainage during construction. In addition builder will almost certainly be in breach of BCA, the contract, good building practice and professional standards. I would get professional independent building report immediately. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Water seeping through slab in a new house 18Mar 17, 2012 10:14 am building-expert I would be extremely concerned about foundation damage and it is more than likely that the builder is not following soil test report recommendations for drainage during construction. In addition builder will almost certainly be in breach of BCA, the contract, good building practice and professional standards. I would get professional independent building report immediately. Are you referring to the OP? I'm interested to know what damage would be caused to the foundation? Im not an engineer so can someone tell me how water sitting against a slab could force its way up through the slab. Working on the premise water finds its own level, wouldn't the water sitting against the slab need to be higher, or, have some pressure source forcing it up. Re: Water seeping through slab in a new house 19Mar 17, 2012 10:37 am Standard building practice is to keep water away from foundations or slab edges. Water absorbed into clay reactive soil will swell and can cause slab heave. I see this type of problem all the time. There are some very bad problems in the Western suburbs of Melbourne. Recently I have appeared on ACA helping people with home foundation damage.(check out my blog) Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Water seeping through slab in a new house 20Mar 17, 2012 2:00 pm building-expert Standard building practice is to keep water away from foundations or slab edges. Water absorbed into clay reactive soil will swell and can cause slab heave. I see this type of problem all the time. There are some very bad problems in the Western suburbs of Melbourne. Recently I have appeared on ACA helping people with home foundation damage.(check out my blog) I agree 100% about the edge heave, it was a major problem a few years back when we were in drought. An aircon con pipe dripping on the ground and creating a wet patch which would swell the ground and heave the slab. I just watched the ACA story, the comment about buying a car without brakes which you used in a previous post, am I correct to assume you are one in the same as the person in the story? If so I'm just curious to know what makes you think you are a building expert? Thanks for your advice. So far i have not noticed any issues with doors and windows. Builder advised they will organise drainers to inspect 2 weeks ago but no further… 7 18828 13 6634 if it's the look that you're not happy with, the easiest option would probably be to spray paint it all into the same color as the walls so it blends in. there might not… 3 4192 |
