Browse Forums General Discussion 1 Feb 27, 2012 7:32 pm Hi guys, please check the attchment for your opinion about the design of my master bedroom.
the size is 490 x 550 (not big) and I want a walk in robe and ENS.......does anyone here got a better idea to make it looks smarter ? Ps: the door must open in south and the window in North....because the limited of the house.... Thanks Kammie [attachment=][/attachment] Re: Help needed...... 3Feb 28, 2012 10:00 am For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6900 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7003 Any structural alteration to your home requires building permit. Before you get it you will have to supply plans with structural assessment, you will also be removing… 2 4111 |
