Browse Forums General Discussion 1 Feb 20, 2012 9:20 am Hi All - after some assistance on the best approach to cutting blueboard. I have trawled the net & have all sorts of differeing opinions, from scoring, to buying diamond blades etc - I am only cutting 2 sheets so would preferably not have to splash huge amounts of $$ on tools to cut them - I have a circular saw & a jigsaw, just not sure if the standard blades will handle this material - any advice would be appreciated. Re: Easiest way to cut blueboard 3Feb 20, 2012 11:16 am Your alternative option would be to fit a masonry disc in your power saw, and a dust mask is essential. Arfur Re: Easiest way to cut blueboard 4Feb 25, 2012 5:34 pm fibro cutters will do it if you only have a few cuts. they dont like it if your doing it all the time. no need to worry about masks, but if you are using cutting discs of any type make sure you wear a proper ventilator not just one of the cheap white dust masks. PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10256 Fine with me... just let 'em step in with some affordable (but good) gear... 12 5498 2 5503 |
