Browse Forums General Discussion Re: Windows overlooking issues 2Sep 21, 2006 4:25 pm I found the Rescode on the www.casey.vic.gov.au. There is a link in the section Services, Building Services where you can download the Rescode file. It contains all the new building regulations in victoria and includes overlooking windows etc...
Kwhy Re: Windows overlooking issues 3Sep 21, 2006 5:18 pm The overlooking clause [4.19]of the Building Reg's has around 10 sections, but basically if your proposed window is within 9 meters of a window or a 'private open space' [outdoor area] on a neighbouring property then you should get a copy or advice. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. I am looking at building a house. Has anyone used Construkt Homes (based in Adelaide)? Does anyone have experience with this builder? 0 6450 12 5320 Industry type domestic contracts are prepared by industry bodies for the benefit of the builders. This means that if you are the owner watch out. One of the points is… 0 3225 |
