Browse Forums General Discussion Re: Solar Hot Water System 4Jan 17, 2012 6:50 pm Yep, I get that, but can I combine the two? As in can I have a Heat pump system with tank and connect Evacuated tubes too it? Or is that just silly? Re: Solar Hot Water System 5Jan 17, 2012 8:30 pm Sorry NiMa, totally hijacked your thread! I did manage to find this http://www.rheem.com.au/images/pdf/owners_loline-elec_126550C_0711.pdf but all it says is the attention light indicates a fault! Not much help Sorry! Solar Hot Water System 6Jan 17, 2012 8:40 pm DestinationTranmere Yep, I get that, but can I combine the two? As in can I have a Heat pump system with tank and connect Evacuated tubes too it? Or is that just silly? I haven't ever seen the two combined. I guess in theory it is possible, but the resulting combination would probably be so expensive as to not be competitive. The time to heat is purely a function of the distance between the hws and the faucet. There are many options for hot water, you can also have a circulating circuit of hot… 1 8661 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 16151 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 18065 |
