Browse Forums General Discussion 1 Jan 15, 2012 6:59 pm We bought a house 1 year ago. The house was renovated in 2009. The extent of renovation: Converted garage under house into bedrooms etc. Problem: Rising damp not addressed prior to renovation. There is a skin of Gyprock placed over all brick work down stairs, but the bricks behind were obviously not damp coursed. Is the builder at fault? Can we get him to fix it? The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15927 Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 20683 Firstly the ableflex that has been installed needs (manufactures specification) a sealant cap over the top, preventing water draining down between the slab and the… 3 7912 |
