Browse Forums General Discussion Re: Wooden flooring 5Jan 14, 2012 12:16 pm A floating floor is just that. They are usually sheets of timber ply or other that look like T & G that clip together and laid over some sort of thin 5-10mm foam underlay. They are not glued , screwed or nailed to the floor at all. T & G timber flooring is nailed to joists /battens etc and much better in my opinion although quite a bit more expensive ( you have to allow for sanding and sealing as well ). Floating floors are a cheaper alternative but the concrete needs to be finished pretty well before laying the sheets. Stewie Old Home Restoration / Renovation To reduce noise transfer without compromising the aesthetic of your exposed I beams, consider filling the 100mm gap between the I beams and the floor above with dense,… 6 9123 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6174 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15887 |
