Hey guys as the title states I'm after Some quotes for ducted heating and cooling . 8 messages left and no one has returned my calls . Decided I'd try here.
Any installers on here ?? Anyon had a good experience ,
Thanks
Browse Forums General Discussion 1 Jan 04, 2012 9:00 am Hey guys as the title states I'm after Some quotes for ducted heating and cooling . 8 messages left and no one has returned my calls . Decided I'd try here. Any installers on here ?? Anyon had a good experience , Thanks Re: Recommended refrigerated aircon installers mernda. 3Jan 04, 2012 9:28 pm Why not investigate multi split instead of ducted. It might be more economical in terms of purchase cost and running cost. 13-08 Moved in 13-05 Build restart 13-04 VMIA compensation 12-08 Builder liquidation 12-03 Fixing 11-12 Lockup 11-11 Frame 11-09 Slab 11-09 Start 11-07 Contract 10-11 2K deposit 10-06 Titled land Re: Recommended refrigerated aircon installers mernda. 4Jan 06, 2012 12:30 pm I would get it installed in autumn or spring, you should have plenty of installers desperate for work then. Metricon Riva 33 - http://herlihy-riva.blogspot.com Site start 15/03/2010 - Handover 23/12/2010 9 months and 8 days (284 calendar days) from site start to handover Re: Recommended refrigerated aircon installers mernda. 5Jan 06, 2012 7:42 pm I would suggest that the reason you have had no return phone calls as we have just finished the xmas/ new year period and most are on holidays! We had ours installed befor xmas and can highly recommend the installer but he has gone away now for 5 weeks. I know someone else in the area but think he may be away too, so will have to check. Maybe have some patience and some of the 8 will ring you back Anybody know any good and reasonably priced Air conditioning contractors/companies that could install a ducted air conditioning system in the Central Coast NSW for a small… 0 8996 The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15798 retail its around double the price of a similar sized actron/dakin system from memory, They are excellent systems though. But with how builder gouge on AC/heating, you… 4 13791 |
