Browse Forums General Discussion 1 Dec 29, 2011 4:34 pm Hello, I am making half of my sheet metal garage into a room. On one wall, I have glued and screwed on a timber window frame to accommodate a double glazed pvc window I bought. The problem is, the hoop iron brace goes right across where the window's going. Can I cut it and anchor it elsewhere or something, or will this seriously compromise the structure? At the moment, the hoop iron is loose and doesn't seem to be doing much. I know it's a bit of a silly problem to be having, but I'm just feeling my way along with this building stuff, I'm not really cut out for it. I don't want to move the frame to avoid the hoop iron. This is the spot I really want it. Hope you can help me out. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: OK to remove hoop iron brace? 2Dec 29, 2011 4:58 pm You should be able to cut it and refix it on the top left of the timber for your window frame. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: OK to remove hoop iron brace? 4Dec 29, 2011 5:03 pm On second thoughts, I would move both pieces of the X to the same horizontal position to make a uniform X. Add another X below the window if you like to be extra cautious. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: OK to remove hoop iron brace? 7Jan 02, 2012 6:49 am mgilla I would think the metal walls would act as a brace anyway, if they are screwed off well i'd just cut it out of the way. Dead right. The main purpose of the bracing is getting it all straight in the framing stage before the sheets of iron go on. Once the iron is on, the affect of the brace is counter actes with the sheets then taking over the bracing. You could simply cut that brace, put the window in, and not worry about re connecting the brace with any ill effect at all. Yes i guess this is one of the main reason as i checked one post foundation 4 9997 We have a Victorian style ripple iron fence out the front that has some moulded timber capping. Probably 15+ years old and has cracked and splintered in parts...not really… 0 2495 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5947 |
