Browse Forums General Discussion Re: Neighbour taking the 200mm of our land 21Dec 19, 2011 7:44 am The more I read about this the more convinced I am that a fence the full length of the boundary should be installed. There are too many things that can go wrong otherwise. Simple and less complications in the future. Demolition August 2009, Construction Started September 2009, Completed December 2010 Neighbour taking the 200mm of our land 22Dec 20, 2011 10:02 am Can you not allow them to utilize the space for 'ground cover only' Maybe get something drawn up, or if your articulate do it yourself, along the lines of 'while I recognise the 200mm space between my garage and the boundary is not a space I can utilize to my benefit I will allow thy Neighbour to USE this space however only allow ground pavers/grass/or sand on this section of land, no fixtures/fittings are to be attached to the outside of my garage wall that faces their property at any time, nor any structures/recreational items placed against it, should I wish to erect a fence at any time in the future I may do so with giving the Neighbour 1 weeks written notice to allow them time to remove any ground cover/pavers they may have placed on my property' Maybe something along the lines of that! Building our own custom design with Redink Pre-start - 28/06/2011 Building license approval - sept 2011 Footings - 8/10/2011 my thread - viewtopic.php?f=31&t=48921 Re: Neighbour taking the 200mm of our land 24Dec 21, 2011 5:57 am I suggest the OP get a copy of the Fences Act booklet from their local council because I suspect IF they wish to erect a fence on this 200mm of land they WILL need the permission of the neighbor --in the booklet under the heading Power of Entry. I think the way the relationship between the OP and their neighbor has deteriorated at present this permission will be denied and the OP will require a Court order (as described in the Fences Act booklet) with written notices hand delivered or by registered post. Its going to get a whole lot messier before its over, and then you have to live next to them for many years -- Good Luck! Arfur Re: Neighbour taking the 200mm of our land 25Dec 21, 2011 7:10 am 200mm from the wall to the boundary, take away half the the width of the fence 77mm and your left with 123mm of space between the fence and the wall. A total waste of space you can do nothing with. In small lot estates this happens with just about every house, people even put there clothes line on the wall with the blessing of there nieghbour. Just let it ride, then if one day you ever decide you want to do something with this strip of land worry about it then. It doesn't have to be just black and white, sure it's your land and your paying rates for it, but really, what does it matter. Re: Neighbour taking the 200mm of our land 26Dec 21, 2011 7:46 am As already mentioned earlier, if the neighbour uses the 200 mm, after 15 years they can claim it. Gone forever! Explain to the neighbour that there are legal complications and that in the interest of simplicity the fence will go in. Inivte them over for a cup of coffee once your settled in. Demolition August 2009, Construction Started September 2009, Completed December 2010 Neighbour taking the 200mm of our land 27Dec 21, 2011 7:56 am At current land values that area would be worth around $3000. Maybe the previous poster should just open a bank account for them and deposit it at 4%. Interest. Re: Neighbour taking the 200mm of our land 29Dec 21, 2011 11:47 am Eve Dweller At current land values that area would be worth around $3000. Maybe the previous poster should just open a bank account for them and deposit it at 4%. Interest. Do you really think the neighbour will give melbournevicau $3000 for the 200 mm by 6 metre strip of land Demolition August 2009, Construction Started September 2009, Completed December 2010 Neighbour taking the 200mm of our land 30Dec 21, 2011 11:59 am I was referring to the post above yours before......... Re: Neighbour taking the 200mm of our land 31Dec 21, 2011 12:44 pm Just thinking out allowed here, when erecting the entire fence which will be on the boundary there will be a 200MM (less share of the fence width) or so gap between boundary and wall. This would require a join in the fence so it would step in. it will look rather funny but I would ask the neighbours what sort of plants they would like planted there and purchase and plant them. Try and offer the hand of friendship and hope it doesn't get bitten, but Unlce above has summed up pretty well. Ciao Mark Re: Neighbour taking the 200mm of our land 32Dec 21, 2011 4:08 pm Casa2 As already mentioned earlier, if the neighbour uses the 200 mm, after 15 years they can claim it. Gone forever! Explain to the neighbour that there are legal complications and that in the interest of simplicity the fence will go in. Inivte them over for a cup of coffee once your settled in. Legal complications??? I wonder when was the last time someone claimed a 200mm strip of land as there own and it was gone forever. What could be more simple than stopping the fence at each end of the garage and forget about a strip on nothing that you can't use for anything anyway. If this piece of land is so important to you, next time you build put the wall on the boundry so the problem is solved. Re: Neighbour taking the 200mm of our land 33Dec 21, 2011 4:37 pm Quote: If this piece of land is so important to you, next time you build put the wall on the boundry so the problem is solved. I agree and wonder WHY you stepped the wall in 200mm from the boundary to begin with? Arfur Re: Neighbour taking the 200mm of our land 34Dec 22, 2011 8:10 am man....seriously, why this type of thread always get so hot up. casa2 is right, although the neighbour does not need to claim it, they only need to prove they have been using this 200mm of land for the past 15 years and no one had raised any objection. they can simply pour concrete or fill with top dress and using it as part of their own property. they will need to hire a surveyor to re-draw the lot size in a few years time to include that 200mm and voila! they have your land. 9/10 times you will find out just after the 15years deadline. mgilla and Uncle Arfur, not sure which state you are in but in VIC, there is a 200mm off boundary line requirement, the 200mm space is meant for fencing, garden bed, pebbles, mulch, weed, or whatever crap you can put on it, it is a distinguish line to separate your block of land from your neighbour. to the owner of this thread, just build a fence it saves you all the trouble for now and future. the land is yours why bother giving it away, even Santa give toys only. Re: Neighbour taking the 200mm of our land 36Dec 22, 2011 9:07 am rojak1 casa2 is right, although the neighbour does not need to claim it, they only need to prove they have been using this 200mm of land for the past 15 years and no one had raised any objection. they can simply pour concrete or fill with top dress and using it as part of their own property. they will need to hire a surveyor to re-draw the lot size in a few years time to include that 200mm and voila! they have your land. 9/10 times you will find out just after the 15years deadline. Thanks rojak1, I'm in Qld and wasnt aware of the 200mm in Vic. Or is this just done to allow the fascia and gutter to sit on the outside of the brickwork and not cross the boundry line. Sitting the gutter on top of the bricks allows you to move the wall hard to the boundry. Costs a little more but is a pretty common practice here in Qld. But even in 15 yrs if your nieghbour does decide to spend the money to have his block re-surveyed, which would be a stupid waste of money in my opinion. What have you lost??? Yes on paper your block is 1.2sqm smaller, but even if you want to sell what possible problem could this present? Also if your nieghbour wants to concrete up to the side of your garage, say thankyou. Why leave a strip of dirt against your foundation where water can pound and cause potential problems. Refer to the CSIRO landscaping recommendations. Cheers Re: Neighbour taking the 200mm of our land 37Dec 22, 2011 4:41 pm mgilla What have you lost??? Yes on paper your block is 1.2sqm smaller, but even if you want to sell what possible problem could this present? What happens when you pull down the garage to make it part of a new house - you'll have a kink in your fence. And should you want to rebuild the garage, you'll have to come in 200 mm from the boundary - we're now up to 400 mm - where will it end? mgilla if your nieghbour wants to concrete up to the side of your garage, say thankyou. Why leave a strip of dirt against your foundation where water can pound and cause potential problems. Refer to the CSIRO landscaping recommendations. If the neighbour slopes the concrete towards the garage you get problems! Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Neighbour taking the 200mm of our land 38Dec 22, 2011 4:44 pm Rojak you've got a good point there!! Re: Neighbour taking the 200mm of our land 39Dec 22, 2011 6:28 pm basing land prices of $200,000 for a 330sq m block, and 1sq of land used by neighbor , it would be $600~ of land value. i'd want my 'rent' on my land. $20/week sounds fair.. *edit, did not read second page before i posted, similar to what eve dweller has said, i went a bit cheaper ___________ Started design Aug 2011 Plans submitted to council Dec 2011 Re: Neighbour taking the 200mm of our land 40Dec 22, 2011 8:25 pm Casa2 mgilla What have you lost??? Yes on paper your block is 1.2sqm smaller, but even if you want to sell what possible problem could this present? What happens when you pull down the garage to make it part of a new house - you'll have a kink in your fence. And should you want to rebuild the garage, you'll have to come in 200 mm from the boundary - we're now up to 400 mm - where will it end? mgilla if your nieghbour wants to concrete up to the side of your garage, say thankyou. Why leave a strip of dirt against your foundation where water can pound and cause potential problems. Refer to the CSIRO landscaping recommendations. If the neighbour slopes the concrete towards the garage you get problems! So if that is the case it would be far better to have the concrete hard against your wall then the the water running off the edge of there slab 200mm from your wall. The fastest thing a builder will do is bank your cheque, those systems work perfectly with lightning speed, everything else is slow burn. Just the way it is. 1 8908 Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18953 Thanks. I called VBA today and they said it was a Consumer Affairs issue, the old handball. Seems like the government organisations don't want to do their job at the moment. 2 7648 |
