Browse Forums General Discussion 1 Nov 26, 2011 8:17 pm Hi there, We are almost about to finish our frame stage. The builder has installed the sub floor for the upper storey prior to putting the roof. With the recent rains in Melbourne we are concerned if the sub floor will start warping due to the rain water falling and sitting on it. Did anyone else experience the same. Is there a reason for us to be concerned with the possibility of sub floor being efected due to rain. thanks Re: Effect of rain on sub floor 2Nov 28, 2011 8:30 am winner Hi there, We are almost about to finish our frame stage. The builder has installed the sub floor for the upper storey prior to putting the roof. With the recent rains in Melbourne we are concerned if the sub floor will start warping due to the rain water falling and sitting on it. Did anyone else experience the same. Is there a reason for us to be concerned with the possibility of sub floor being efected due to rain. thanks if they are using "yellow tongue" particle board (which is pretty much standard) then it should be covered and protected from the elements no later than in 3 month after installation. Re: Effect of rain on sub floor 3Nov 28, 2011 10:18 am yellow tongue flooring is guaranteed for up to 3 months in the rain, if you don't know what yellow tongue is just look at the plastic strip that inter connects the flooring together, it is coloured yellow, also they should be staggered, liquid nailed and nailed using 3 inch framing nails, at least 4 a row. Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28761 Hi, does anyone have any experience with using Trex rain escape or EPDM rubber to waterproof a deck so you have dry space underneath. Popular in the US and realize that… 0 3417 Yes you are correct, unless there are outside works which form part of the contract such as landscaping or driveways, and importantly, the work delayed is on the critical… 1 3499 |
