We are in an older property in northen Sydney, and we had recent trouble turning the water off at the mains.
Who is actually responsible for the stop-cock - us or Sydney Water?
Browse Forums General Discussion Re: not able to turn water off at the mains - who owns the t 2Nov 16, 2011 10:35 am Generally the water board are responsible for the stop tap. If you don't pay the bill they will shut it off! The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: not able to turn water off at the mains - who owns the t 3Nov 16, 2011 11:23 am thanks for your response - in the meantime I did find some info (link provided below for others that maybe interested) Looks like they will do it as a 'courtesy', I will try to remember to come back and give an update of what actual happens. http://www.sydneywater.com.au/AskSydneyWater/ stick "I can't turn off my water meter tap" in the search box if it's the look that you're not happy with, the easiest option would probably be to spray paint it all into the same color as the walls so it blends in. there might not… 3 4181 Can a plumber put a tap on a rain water tank which is full? Tank is similar to one in photo. Cheers. 0 1664 that will depend on the kitchen bench depth. you'll have to specify it so it allows for both the tap and the sink 1 7381 |
