Browse Forums General Discussion 1 Nov 02, 2011 11:05 am Hi guys I have a spanline metal roof on an enclosed verandah. I need to remove the smoke from my barbecue. I am going to purchase a range hood with a 300mm square flue and I am wondering what would be the best way to flash around the flue. Re: Flashing for Rangehood flue in metal roof 2Nov 02, 2011 12:39 pm A product called Dektite But I'm pretty sure the actual flue piping won't be 300mm square. A very odd size if it is. Usually the flue cover is that size and the piping is between 150-200mm round. http://www.deks.com.au/products_australia.htm I know this post is from a while ago, but the VBA has some good guidance on this. https://www.vba.vic.gov.au/__data/asset ... 5-Roof.pdf 2 10625 Cheers. The painted render is a bit chalky to the touch. To prepare the surface for best adhesion, what would you recommend? Also, given that there must be some… 6 8509 AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6277 |
