Browse Forums General Discussion 1 Oct 25, 2011 9:23 pm Hi, any ideas on tile removal on fibre cement flooring? Need/want to remove tiles without damaging existing flooring so i can tile over again, without fuss of replacing floor. Cheers. Re: Tile Removal 2Oct 26, 2011 9:14 am Anytime I've removed tiles I have always removed the cement sheet as it is very difficult to remove them without damaging the cement sheet. Then the new cement sheet is a lovely clean surface to work on when retiling. So I can't really help you sorry Re: Tile Removal 3Oct 27, 2011 4:11 pm As the previous poster said it wont be easy and you may have to cut the tiles into smaller sections with a small angle grinder then carefully take them up. I think where you will have most trouble is removing the adhesive to give you a flat surface to re-lay on. Arfur DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 6335 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6711 PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10246 |
