Browse Forums General Discussion Getting Power to your house site in SA. 2Oct 16, 2011 8:05 pm "normal" depends on where your site is. If you are in a standard urban sub-division, then, no it doesn't sound normal. If you are in a more rural environment, where power isn't "at the gate" then it is quite possible for the costs to be substantial. Your only real alternative is to stay off the grid and use solar with batteries. Paul Re: Getting Power to your house site in SA. 3Oct 17, 2011 2:48 pm A couple of questions to clear some stuff up as mentioned above. Where are you located? Is it Suburban/Semi Rural/Rural/Uber Rural? How big is your block of land? How big a set back do you have? Is there power (above ground) on the street? If there is power there, you may be able to reduce costs by seeing if you can dig you own trench. I'm pretty sure there has to be 600mm of soil above the top of any conduit it runs in. If you can get a ditch machine for a couple of days even a big block wouldn't be hard to do. Make the ditch around 700-800mm deep and maybe 300mm wide. That should cover the trench requirement. Getting Power to your house site in SA. 4Oct 17, 2011 4:48 pm For the amount of money quoted I am assuming that high-voltage work is required - which means poles and transformers. If you have neighbors then I believe you can recoup some of the costs from the electricity company if someone else subsequently connects to the poles/transformer you paid for, but that doesn't help upfront Paul Use a product like Equisol's Vitalise to clean the deck then coat with a penetrating timber oil. It will look 10 years younger and add value to your home. Visit for… 1 15763 How much are you ahead in payments compared to where the build is at? Have you fully drawn down the loan? 5 11893 Finding the right construction lawyer can be a bit daunting, especially when you've had some challenges in your search. It's essential to have someone reliable and… 7 24885 |
