Browse Forums General Discussion 1 Oct 11, 2011 8:31 pm I want to build a toilet into a small room in my shed, but im not sure what size this room should be. I want it as small as possible, but are there any regulations i need to follow? thanks in advance Josh Re: What size should i build my shed toilet? 2Oct 11, 2011 8:45 pm 900mm wide by 2000mm deep is about the smallest you'll get into after fitting it out. That is to walk in turn around shut door and sit. Re: What size should i build my shed toilet? 3Oct 11, 2011 8:57 pm chrisandkate sit. Typo? Geoff - Decophile. What size should i build my shed toilet? 4Oct 12, 2011 6:50 am I think ours in the garage is around 2000 x 900 - that allows for a vanity up one end and the toilet down the other (the door in centered on one of the longest walls) Some things are worth waiting for. Re: What size should i build my shed toilet? 5Oct 12, 2011 8:09 am 2000 x 900 is good size, but my sisters house which is brand new is only 1500 x 900 and it works ok. I am pretty sure there is a law in our state that says the door has to open outwards, in which case it is easy to get people out if they collapse in the dunny. What size should i build my shed toilet? 6Oct 13, 2011 6:04 am Yes, under the BCA either the door has to open out, or it needs to have lift-off hinges. Most houses (mine included) seem to go the lift-off hinge route as it looks neater than an outward opening door. Paul Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4889 Thanks. Yeh ideally that would have been good, but have progressed too far now. Hoping some well placed internal walls fixed up into the battens will provide some… 2 5370 Hi, I am sheeting the inside of a 5.7 x 8m shed with gyprock. Unfortunately the shed wasn't designed for internal cladding but I have been framing it up as strongly as… 0 3399 |
