Browse Forums General Discussion 1 Oct 03, 2011 4:58 pm Just wondering if anyone has used this product called Platon. I have a subfloor which I need to turn into a room and wondering if the cement floor requires some other waterproofing prior to laying. There appears to be a small amount of moisture from the floor but this product apparently is made for this type of situation. System Platon is a tough, durable, environmentally friendly, double dimpled, high-density polyethylene air gap membrane. Any feedback would be greatly appreciated. Thanks in advance. Hey There. No problems re jumping in. My original question was "should I have waterproofed" the concrete slab before putting batons down. We have been told we should… 7 4329 Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28820 I have researched this topic in detail recently but for another state which has no licensing requirements at all so any handy man can waterproof any old way and not have… 1 8480 |
