Browse Forums General Discussion 1 Sep 22, 2011 4:00 pm we have recently looked at a house for sale that was built in the 1960 or maybe 1950s The exterior wall cladding looks like weatherboard but is clearly a board that is 3 weatherboards high and is held by flat nails which are all clearly visible. Neighbouring houses appear to have the same material at first sight. It has a few layers of paint on it and is hard to judge any original surface. When tapped it "sounds" like wood rather than cement sheet or metal and in one place at least has a small jagged crack that goes for about 10-15 cms. The crack also looks like a wood-type break. Any suggestions as to its composition or name? Cheers Re: recognising an unknown wall cladding from the 50s or 60s 3Sep 22, 2011 8:21 pm The '3 weatherboards high' description sounds like the old cement fibre sheet, that came in about 2.4m lengths, which would crack. Im not sure if they contain asbestos. Ditto -- a photo would help Arfur Hi Everyone, Ripped up the carpet and the surface below gas come loose and you can see the slab below. The material breaking away looks and feels like crumbling cement.… 0 10180 Hi, Currently building, we are on a sloping block so we have from floor level to the roof in axon cladding. Below floor level to the ground I want to put brick facings /… 0 4548 Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12109 |
