Browse Forums General Discussion 1 Aug 23, 2011 5:18 pm Hi All, recently I have had a extension completed turning my double carport into a three car garage. It has been raining quite a bit here in Perth recently and I am starting to notice damp spots (fairly large) on the wall(WEST side) and also something that looks like a white fungus. Is this something I should be going back to the builder about?? Or do I have to tackle the problem myself.... The wall on this side of the property is 4-5 courses of brick lower than the next property but I would have thought that the builder would have taken this into account. Cheers Bartos Re: New extension - Rising damp??? 2Aug 23, 2011 9:12 pm The white fungus sounds like efflorescence which is not a fungus but the salts etc coming out of the bricks. Fairly common especially with new bricks/pavers. It should just brush off. Given that it is a garage I am thinking that it is just single brick construction. So it may be some damp coming through especially if that is on the weather side. Clay bricks are fairly porous. Not sure about the building regs regarding this but I did'nt think garages had to have a damp course but I could be wrong. Hopefully someone else can help you out with that. Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 21247 Firstly the ableflex that has been installed needs (manufactures specification) a sealant cap over the top, preventing water draining down between the slab and the… 3 8289 Hi all Am new to this forum. I want to get some ideas/info about how to manage an 80 year old factory restoration to convert to a residence. The factory floor is concrete… 0 6978 |
