Browse Forums General Discussion Re: Running PVC through a strip footing 2Aug 25, 2011 3:03 pm I found this on my engineering report - Where plumbing pipes penetrate the footing beams, they shall be lagged with a min. 20mm thick closed cell polyethylene material or similar approved. Lagging to extend from soil face to soil face of sides of footing beam yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7321 2 6192 Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20182 |
