Browse Forums General Discussion 1 Aug 10, 2011 1:37 pm Hi Folks, Need some advice on this ! I moved into my propoerty last year and when it rained for the first, only then we realised that the storm water drain pipe was blocked and water was overflowing the LPOD (legal point of discharge) in the front yard. I then contacted the builder and they did some investigations and came to the conclusion that the block is under the nature strip. They brought some equipment out for this like camera, high pressure drain unblockers, etc. Since the blockage is under the nature strip this should be fixed by the council. I then contacted council, who did their own investigations and said that it should wither be fixed by the owner or the builder. They were adament since this is a new property it should be fixed by the builder as it may be clogged up with all the building materials. This has been going back and forth and I am kind of watching the pinog pong. During the last investigation by the builder they claimed that the pipe is not connected to the council mains at all as the high pressure equipment was just turing out dirt. Not sure what to do here, my front yard landscaping work is also held up because of this. Any advice/suggestion here will be highly appreciated. Cheers, Rahul Re: Storm water drain pipe blocked 2Aug 10, 2011 3:33 pm Grab some popcorn and watch your builder and the council fight it out? At least you're not being asked to pay for anything. Moving into a new house calls for a lot of patience. Metricon Riva 33 - http://herlihy-riva.blogspot.com Site start 15/03/2010 - Handover 23/12/2010 9 months and 8 days (284 calendar days) from site start to handover Re: Storm water drain pipe blocked 3Aug 10, 2011 4:06 pm Just be patient and do all the right things nobody can harm you if you are right. Re: Storm water drain pipe blocked 4Aug 10, 2011 4:10 pm btherl Grab some popcorn and watch your builder and the council fight it out? At least you're not being asked to pay for anything. Moving into a new house calls for a lot of patience. It doesn't look like it's going anywhere as the builder has clearly said that they are not going to fix and so has the council ! Re: Storm water drain pipe blocked 5Aug 10, 2011 7:39 pm What's your LPOD (legal point of discharge) in the front yard? A council stormwater kerb outlet or something else? How difficult / deep would it be for you to do some investigations on your own (aka digging)? Or is it completely impossible due to some unknown (to the readers) reasons? My signature is distracting people from my wise posts ... Re: Storm water drain pipe blocked 6Aug 10, 2011 9:44 pm The builder's investigation says that the pipe is 700mm below the nature strip. LPOD is the pipe to which all the downpipes connect to, it is a pipe that is laid by the estate developer connecting the council barrel drain to the property. Re: Storm water drain pipe blocked 7Aug 11, 2011 3:16 pm Well since they are stuck, I think you should go for the builder. You have a contract presumably stating that your builder will provide stormwater drainage. They didn't provide it, therefore they did not complete the works specified in the contract. Let them know that you understand they are in a dispute with the council and/or estate developer, but that you need drainage NOW, and they can resolve their dispute in their own time. If the builder really believes it's not their problem then they can fix it themselves, document what they found and then pursue whichever party caused the problem to recover their costs. That's what I'd do if I still didn't have stormwater pipes connected after a year. Metricon Riva 33 - http://herlihy-riva.blogspot.com Site start 15/03/2010 - Handover 23/12/2010 9 months and 8 days (284 calendar days) from site start to handover Re: Storm water drain pipe blocked 8Aug 15, 2011 5:11 pm Get the drains scoped properly, and determine whether or not they have Been conected out to the council pipe properly/ and or where the blockage is. This info. Can be video'd and given to you on a disk as proof. If your in Sydney pm me and I'll give you my friends number, he does this type of work. Storm water drain pipe blocked 9Aug 16, 2011 7:05 am Hi I can't understand how the council can claim that this isn't their problem (well, they are a council so I can understand how they can claim it, but I still think it is their problem). As I understand it your pipes are delivering the water to the LPOD, so there is no blockage on your pipes. The definition of LPOD says it all. It is the point where you may legally discharge your storm water. If the blockage occurs after the LPOD then it is in the council service - I think of it like the water meter or electricity meter - it is a service boundary. Anything on one side is my problem, anything on the other side is the service provider's problem. Developers are required to provide this sort of infrastructure when they create an estate, but this infrastructure passes to the council once the developer has finished. You say you have tried water jetting (which makes sense - why fight with council when you can solve the problem relatively cheaply yourself) and it appears the pipe isn't connected properly - this is something the council should take up with the developer or just rectify themselves (council are supposed to inspect the infrastructure before accepting it) - either way it shouldn't be your issue. Have you tried contacting your councillor? Paul Agreed. I just found out today the certifier has not given the final sign off. 2 4098 Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 7816 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 6846 |
