Browse Forums General Discussion Re: Merbau side gate 11Aug 15, 2011 4:37 pm sco77k Hi Everyone, Quick question, I've just had 2 merbau side gates installed on our house and was a bit surprised to find that you can only open and lock the gates from the backyard. The guys who installed them didn't cut a hole so you can reach through and pull the bolt to unlock the gate from the front. Is this normal? I was hoping for something like this, which is does look similar but doesn't have the hole to open on the other side. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I've tried calling the installers but they are not answering their phone! What are your thoughts? Could I cut a hole in the merbau myself? Thats a great look gate (even if I do say so myself!!) When I make this I simply put a piece of merbau on a 45 degree angle, marked it, cut it and screwed in in place. This has been working a treat ever since. It was by no means hard and i replicated it at the front also... The reason I liked this idea was for the front gate I was able to incorporate a padlock to stop people coming in, where most other systems did not allow this. Hi, Building a new place and I have limited space from garage to fence. 3130mm width, then opens up over 5000mm once I pass tmy garage. I need a fence that goes from… 0 3330 I should have followed up on this thread. So, the pier foundation wasn't large enough on the side it was leaning towards, and the NBN cable went through the pier, just… 8 12133 Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9084 |
