Browse Forums General Discussion 1 Aug 07, 2011 8:46 pm Anyone know a supplier (melbourne) or have tips on how to get an entry door and garage door made to match? We like the look of a lot of the western red cedar sectional garage doors, but want to match the entry door. Entry door similar to what you can see here: http://www.moarwindows.com.au/index.php ... &Itemid=61 under (Faulkner Horizontal Plank). What's the best way of doing this? Is there anything off the shelf, or should we get the garage door made, and then have someone custom make matching entry doors. 2 Entry doors are 2400x870, and garage door is 870x2100. We want to stain ourselves so that we can go a significantly darker color - closer to walnut or venge. thanks my house blog: http://sugarloafdrivebuild.blogspot.com/ I ran into trouble finding a lock that would fit my particular door, like your situation with your pivot door. I wanted a safe lock that couldn't be messed with easily. 4 25685 Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 4593 I am looking to design an entry door to a lower ground basement that has 2200mm between the external entry height to FFL of the ground floor. This door will provide an… 0 1505 |
