Browse Forums General Discussion 1 Jul 26, 2011 5:52 pm Hi everyone i am new so hope i have put this in the right section. i am looking for a house that will eventually be extended and this house is one of very few i can find in my price range that has the immediate needs either in place or able to be put in place......small kitchen and en suite the roof is bothering me however. it is a timber house which is not my first choice but .....that seems like it is too bad right now. it has minimal slope to each side from the centre .........one of many such houses around the area. i have asked if the roof is insulated but got no answer. i am assuming it is not.....given the shape. given all the glass at the front (it is east west facing) i can only see huge leakage of warm air in winter and huge heat in summer. the house is full of venitians that only go part of the way to the top of the windows. because of the shaping of the windows i am assuming. canvas blinds over the front of the windows i suspect wont work as they will interfere with entry to the house. some of the current shade trees will have to come down in the longer term at the front.(east) the back will continue to have some shading in the afternoons. does anyone have any thoughts about insulation please. i dont feel the cold much but the heat is another thing for me. the house has been well heated when open for inspection which suggests again that it is not a warm home. its position geographically is reasonable and the price is likewise. i am just getting skittish re the temperature possibilities any changes will be on a tight budget. is it possible to reroof these sorts of houses?? (i realise that is not a cheap thing any thoughts will be most welcome.....thank you ETA......OK i think i cant post the link to the photo as it belongs to the estate agent. so i can only say that it is a roof with a central gable that has no more than about 15 degree slope and is like the roofs of those metal garden sheds. any help is appreciated Re: near flat roofs.........insulation of..sorry cant find a 2Aug 04, 2011 11:18 pm Do you mean the roof is timber or the ceiling lining is timber??
In near flat roofs or cathedral ceilings you can use foilboard. If you replace the roof it will sit directly under the new roof. Otherwise, it will fit between battens above the ceiling lining. It is possible to replace a ceiling. The cost will depend on whether you are just replacing the cladding, or changing the cladding (ie. going from tiles to colorbond), and therefore requiring support structural changes Re: near flat roofs.........insulation of..sorry cant find a 3Aug 05, 2011 10:17 am It is difficult to retrofit insulation into near-flat roofs. You'll either have to take down the ceiling plasterboard or lift off the roof - the former probably easier and cheaper. You can take off portions of the ceiling plasterboard and put in concertina foil between the rafters, they are good for keeping heat out because they are reflective. Concertina foil is also very cost effective. Bulk insulation is better for keeping heat in, but only truly effective in combination with foil. I have near-flat roofs too but I have to put in all new roofing. So I am doing foil (glareshield) over the battens, then two layers of foilboard - one between the rafters, and one under. If you want to spend the time to take down all the plasterboard, putting foilbard up then putting the plasterboard attached to that is a good way to go. Here are my roof details Newtown rebuild: https://forum.homeone.com.au/viewtopic.php?f=53&t=48977 Re: near flat roofs.........insulation of..sorry cant find a 4Aug 05, 2011 4:39 pm I have a 5-8 degree pitch on my new roof but put in sarking before the roof went on and insulation in before the ceilings went up. Have done this in the build because of the difficult access issues post build. Might be easier to lift the old roof for insulation installation. Re: near flat roofs.........insulation of..sorry cant find a 5Aug 05, 2011 8:42 pm If you send us the picture then it will be easier. Otherwise it will be like shooting blindly and hoping it will hit the target. Re: near flat roofs.........insulation of..sorry cant find a 6Aug 05, 2011 8:52 pm If the roof is iron, you can easy lift the sheets and pump or insert insulation. The roof is the most important are of a house to insulate. Depends how cold it gets where you are, but the norm now is for somewhere around R3.5 for roofs. The walls are the second important area, and usually around R2.5 Timber clad and gyprock internals ? Can be done but this is a bit harder. Possibly remove the gyprock (expensive and messy), possibly pump in through holes ? Not sure here as I have never had to deal with it personally. I would contact a professional insulation company for advice (One where Peter Garrett does not work at ) Re: near flat roofs.........insulation of..sorry cant find a 7Aug 11, 2011 8:19 pm thank you so much everyone. i didnt get back to this thread after i didnt see a reply for a bit . the house has a iron roof. gyprock for ceilings....not cathedral retro fit is seemingly the answer then....somehow. my own house offer fell tho so my offer on this or any other house is now in limbo . this house is still in the running tho ....if i get a sale. now i know it is possible to do... i will get someone to quote me if it goes ahead. the house will be both cold and hot.....raised wooden floors, which i would keep, are great for summer.... but not so much for winter .......unless they also are insulated. which makes the house uneconomic to do that. i thank you all heaps for your thoughts and ideas. they are appreciated Re: near flat roofs.........insulation of..sorry cant find a 8Aug 13, 2011 8:29 am Bradford also have a high performance batt that is 90ml thick, and will give an R2.7. This can sit on the ceiling with no air gap below (needs the batten air gap above. They also have a 70ml thick one that gives an R2 rating. You wouldn't need to re=roof to put it in. We were going to use foilboard, however, dust sitting on the shiny surface reduces the effectiveness of the insulation, and we are in a very dusty area, so we are going for the high performance bulk insulation. Added bonus is it is made in Australia, whereas foilboard is imported. Support the home grown product Sorry! I'm new to this forum and have made a mistake in my posting! I'm looking for a structural solution to a stand alone wooden pickets fence with no structural rail… 1 3290 Our standard double-glazed window is tested to achieve, Rw 34, and can be glazed to suit Rw 39. The price is good too... 3 9472 I would suggest you simply go and talk to council about your proposal, most councils are getting onboard with ancillary dwellings. There is no benefit in keeping it… 1 4106 |
