Browse Forums General Discussion rendering facade after handover is possible? 2Jul 20, 2011 6:32 am Out of interest how much per m2 is the builder quoting? It should be around $50-$60 Paul Re: rendering facade after handover is possible? 4Jul 20, 2011 10:16 am The only thing is we are at the maximum of our budget now, so I am looking for the stuffs that I can do after the handover like cooling, driveway, fencing, landscaping, custom shelves in robes etc. Builder agreed to allow my own sparky to the site, so will run the data cables on that time. Now the builder is quoting $3000 for render the front facade. Like to know does it cheaper if I do later? I dont know about the m2 though. Re: rendering facade after handover is possible? 7Jul 21, 2011 8:45 pm Sure, if you are undertaking other jobs post hand over, the render(and then painting) is simple to arrange. Because the house will be finish the quotes will be very clear as to whats included. Also make sure you use the cheapest brick with the builder so your not covering $$ bricks. Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7497 Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4896 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5236 |
