Browse Forums General Discussion 1 Jan 22, 2008 8:19 am Hi all, new member so sorry if this is in the wrong forum.
I have a block of land (still has old house on it) which I want to develop in about 5yrs or so. The block has a frontage of 21m and a depth of 44m. Over the length of the block, there is about a 2m drop in total towards the back (ie. frontage is the highest point and declines from there). I plan to put three dwellings on the block when I develop. My question is whether this slope is excessive and will cause problems and major extra costs during construction? Or is a 2m drop over 44m depth not that bad? Cheers Steve Re: Slope in block 2Jan 22, 2008 9:29 am Hi Steve,
I've seen townhouses built on a similar block of land with about a 5m slope - so it shouldn't cause too many problems. Those townhouses however were quite expensive because of the cost of the slab & engineering requirements. After 4 years - we're in! Re: Slope in block 3Jan 22, 2008 9:35 am Thanks Stonecutter. As a matter of interest, was it just 2 town houses on the block? Re: Slope in block 5Jan 22, 2008 10:41 am _Al_ Where are you located. I think you'll find you can only fit two on a block 840m2. Check with council obviously.. His block is 924m2... assuming it's a rectangle. Re: Slope in block 6Jan 22, 2008 10:49 am Steve - I think it was 3 - long driveway down one side for access. After 4 years - we're in! Re: Slope in block 7Jan 22, 2008 10:51 am Yeah it's a rectangle. Land is 925m2, so plan is to put 3 community title dwellings on the block with driveway down the side.
Someone mentioned to me that I may run into problems with drainage as the block is sloping away from the street. Re: Slope in block 8Jan 22, 2008 11:00 am steveadl01 Someone mentioned to me that I may run into problems with drainage as the block is sloping away from the street. Then it'll be waterfront property. Bonus! Or is that waterback property? Re: Slope in block 9Jan 22, 2008 11:41 am You also need to be aware of the tax implications of becoming a developer and make sure you step on the right side of the line for that one once you get started.
Re Drainage - yes it needs to be catered fro and if you have lots of concrete, it is going to change what is already installed pipe sizing wise etc. Make sure you review all costs before you start diging. Steve A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 223604 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 24852 Hi All, We have recently purchased a sloping block (3.5m fall building envelope, 6m overall). Just wondering if you know of any good builders that you would recommend for… 0 1769 |
