Browse Forums General Discussion 1 Jul 12, 2011 10:05 pm hi there guys, I am in the process of renovating a recently purchased house and looking to rent it out to a friend. Im wanting to know what is necessary for the purpose of setting up a private agreement without agents.. given that it will be a negatively geared investment property thanks for your help spiro Re: renting property privately 2Jul 12, 2011 10:37 pm Hi Spiro, I've found the below 2 sites really helpful to privately manage my rental property: http://www.commerce.wa.gov.au/ConsumerP ... /index.htm http://www.rentalagreementsdiy.com.au/b ... enancy.php They will give you all the forms you need, as well as info packs on your rights and responsibilities as well as the tenants rights/responsibilities. Even though you are renting to a friend, the best thing is to use all the standard forms, and get absolutely everything in writing, just in case something goes wrong. Make sure you do a full initial inspection report, and take lots and lots of photos - I took literally hundreds - inside cupboards, inside oven, appliances, gardens, whatever you can show in detail. If anything comes up at a later date that you disagree over, it could make a difference to your friendship if you have documentation to back you up. Good luck! Re: renting property privately 3Jul 12, 2011 11:23 pm http://www.commerce.wa.gov.au/ConsumerP ... /index.htm http://www.commerce.wa.gov.au/ConsumerP ... mended.pdf Spiro, i have used this website in the past. All forms provided by the government for us to use free of charge. How nice of them!! First link gives you a list of all the forms, second link is the specific link to the tenancy agreement. Also check out the bond lodgement form, you will find it amongst the lists link. renting to a friend can be interesting. Designing a house for one can be even more interesting!! Good luck with the rental. Re: renting property privately 4Jul 14, 2011 2:59 am Hi Spiro, Have you looked into doing a "Letting Only"? Having a Property Manager do the paperwork, take care of the bond lodgement should be hassle free for you and it usually doesn't cost an arm and a leg Holly We've had the offer of a short term tenant whilst waiting for CDC/DA home approval and demolition for our knock down rebuild. It would achieve a pretty low rent as it's… 0 13759 You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16148 Ask for some kickplate to be added and also for tradies to be requested to use lanyards on tools on that side of the building. Be respectful and have the discussion… 1 1698 |
