Browse Forums General Discussion Re: Standard (minimum) width of stairs 5Jul 10, 2011 9:59 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Standard (minimum) width of stairs 7Jul 11, 2011 12:15 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Standard (minimum) width of stairs 10Jul 15, 2011 10:29 pm Architect, the minimum width is not in the BCA. You have to refer to the Aust. Standards. Sounds crazy they cover most other items but not the clear width. (Unless its a required fire egress then it would be 1000mm clear between obstructions.) I just measured my stairs and they are 920mm clear. Re: Standard (minimum) width of stairs 11Jul 15, 2011 10:37 pm david, you are correct. i had a look this morning and couldnt find anything in there. the 750mm that i thought existed related to min landing length. i am used to looking at the BCA Class 2-9 and not 1-10. 2-9 more comprehensive on stairs as you pointed out with widths for egrees outlined HHCIB looks like you can make the choice here. from most comments made I think most people are in agreeance 900-1000mm min in width. Good luck with the reno. Re: Standard (minimum) width of stairs 12Jul 16, 2011 2:48 pm Thanks David and Architect.... very helpful and very much appreciated... thanks guys. HHCIB Re: Standard (minimum) width of stairs 13Jul 17, 2011 12:30 pm architect david, you are correct. i had a look this morning and couldnt find anything in there. the 750mm that i thought existed related to min landing length. i am used to looking at the BCA Class 2-9 and not 1-10. 2-9 more comprehensive on stairs as you pointed out with widths for egrees outlined HHCIB looks like you can make the choice here. from most comments made I think most people are in agreeance 900-1000mm min in width. Good luck with the reno. I agree with architect, when I was looking for this info I couldn't find any reference to width only risers and goings and of course ceiling height - which isn't under 'stairs'. I think there used to be a minimum width but got changed over time Also I think the reason is that for example if you are accessing a non habitable room like an attic then the width doesn't come into it because an attic ladder is only around 400mm wide. Habitable rooms have different specifications. We will be putting in stairs instead of an attic ladder but will only have 700mm (all enclosed) - this will be difficult for getting anything up there that is large but we plan to lift things in via a large dormer window or during the build, 900mm+ would be far better if you can Re: Standard (minimum) width of stairs 14Jul 17, 2011 3:03 pm As tricky as it might be... do you think that 900mm (potentially all enclosed) would be adequate for getting furniture up/down - not huge almighty pieces but say a standard sofa/beds/mattresses/bath etc? We might be able to lift stuff in prior to finishing off but in the long run, you need to be able to get things up/down the staircase if need be. So... anyway, would 900mm be ok do you think (and like I said, possibly fully enclosed, so no room to hang things over the side of ballustrades). HHCIB Re: Standard (minimum) width of stairs 15Jul 17, 2011 10:44 pm Ok, dont quote me but i think the minimum is 630mm. I will check tomorrow. Re: Standard (minimum) width of stairs 17Jul 19, 2011 9:28 am Thanks architect. Just about to reply. HHCIB Re: Standard (minimum) width of stairs 19Jul 20, 2011 3:30 pm Stair regs. Are mainly about tread/rise and pitch also min. Headroom off bulkhead. Twice the rise + going must fall between 550 - 700 mm. Keeps angle correct. I think around 42 degrees is optimal. Width is up to you, but consideration for furniture access is your main concern, 950 over stringers is pretty common I think. My land is 260m2 (10m x 26m) located in claymore NSW. Under campbelltown council. I know in general the following setbacks would apply ground floor side setback =… 0 6936 Hi, only for walking. It is a narrow 1.5m paved area next to house. 2 5441 Thanks Draftroom that definitely helps a heap. We are still at the very early stage of planning to see what kind of house would fit on our plot. While we are on a… 3 15781 |
