Browse Forums General Discussion 1 Jul 06, 2011 10:13 am I am so happy that after 9 and 1/2 months the slab is finally down. on the whole I think that it looks like a good job but I am a bit concerned about a few things and just don't know enough if these are okay. Firstly overall pics of the slab Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ These are the couple of things I'm worried about: 1. Plumbing - this is right on the edge of the slab (as opposed to being completely encased). Is this okay? Will it affect the integrity of that area of the slab or the pipe? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ and Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 2. Minor chips in the end - obviously it doesn't look great but seriously is it a problem or is it nothing to me concerned about and will be hidden in the framwork? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ and Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Obviously I can point these out and ask my SS but I want to get an independant opinion so I get the right answer no just the easy answer. Re: slab down - is this work okay. 2Jul 06, 2011 10:21 am sorry first time posting actual pics and didn't realise I had such large pics on my blog. Re: slab down - is this work okay. 3Jul 06, 2011 10:24 am Chips off the edge are always going to occur, i don't think that's an issue. It could obviously be an aesthetic issue if you've got a chip on your garage crossover, but the ones around the edges will be covered by frame and brick/cement sheet anyway. I presume the plumbing has been put there for a reason, and don't think it'll be an issue either, but i don't know. Homestead Homes SA: The Lamont Bayswood Estate; Aldinga Beach Preliminary Signing: April 2010 Floorplans: 13 June 2010 Building Contract: 19 June 2010 Selections: 28 Sept 2010 Scraped; Trenching: 21 Jan 2011 Slab Poured: 28 Jan 2011 Framing: 17 Feb 2011 | Completed 24 Feb 2011 Roof & Gutters: 02 Mar 2011 Bricks: 03 Mar 2011 Wire-up: 12 Mar 2011 Re: slab down - is this work okay. 4Jul 06, 2011 12:01 pm rockabilly_kid Chips off the edge are always going to occur, i don't think that's an issue. It could obviously be an aesthetic issue if you've got a chip on your garage crossover, but the ones around the edges will be covered by frame and brick/cement sheet anyway. I presume the plumbing has been put there for a reason, and don't think it'll be an issue either, but i don't know. The exposed edges (i.e. alfresco, porch, and gararge) I think are all okay but will double check. The plumbing you are probably right but even if it's okay as far as the pipe/slab are concerned it may then be in the way of the where they have to lay the frame?? will have to check. Does the frame have a a post along all of the perimeter? Re: slab down - is this work okay. 5Jul 07, 2011 9:34 am kdgirl, we had a pipe in the exact same position as yours where it was not completely encased in the slab. I didn't bring it up with my SS but the builder next door came around to have a look and said its fine. The frame went on the inside if the pipe so this was not an issue. I also had an independent inspector go through before plaster went on and he did not bring it up. Building the Benham with Rawson Homes in Western Sydney. Re: slab down - is this work okay. 6Jul 07, 2011 9:39 am are you having a wall hung vanity,with wall hung pipe is placed into wall cavity.Where does first run of bricks go if there is no slab for foundation of walls etc. Re: slab down - is this work okay. 7Jul 07, 2011 10:16 am roverer kdgirl, we had a pipe in the exact same position as yours where it was not completely encased in the slab. I didn't bring it up with my SS but the builder next door came around to have a look and said its fine. The frame went on the inside if the pipe so this was not an issue. I also had an independent inspector go through before plaster went on and he did not bring it up. Thanks Rover, you have certainly put my mind at ease over the location. My only concern now is that looking at the plans i think that there should have been two. I have asked the SS to check this. Re: slab down - is this work okay. 8Jul 29, 2011 8:30 pm Re: slab down - is this work okay. 9Jul 29, 2011 9:25 pm They will cut out the frame to free up the pipe. It will be OK, except that 3 studs are right there, and it seems that 2 of them will also need to be cut out (but hopefully only 1). I would just make sure that they "replicate" those studs very close by, on the other side of the pipe, and also on the other side of the stud (but this really depends on what the studs are carrying exactly, ie. what's sitting on these studs). IMO. My signature is distracting people from my wise posts ... Re: slab down - is this work okay. 10Jul 30, 2011 1:06 pm I think you are worrying needlessly. If that large pipe was merely a conduit for services, the tradies will bore holes through the bottom plate, which has no structural strength, to access the conduit. Arfur How long is a "long period"? For a few weeks, it should be ok. It also depends on the area you live in...I would let your neighbours know that you will be away too and… 1 28600 Hi HomeOne, I'm in the midst of landscaping a cat run down the side of my house, and the recent rains have me wondering if I need to install some sort of drainage. I've… 0 12418 Hi I live in a 100yr old semi and my neighbour added an additional floor last yr and our architect has advised that we can knock down our semi and build a free-standing… 0 37847 |
