Browse Forums General Discussion 1 Jul 04, 2011 5:59 pm While visiting me for another reason, the Council inspector pointed out that an expansion joint in one of the brick walls hasn't been caulked. It looks like a simple enough job, but I don't want to do the wrong thing. Can someone tell me what caulking product is suitable for the job? Thanks in advance, Spike Re: Caulking an expansion joint 2Jul 04, 2011 6:23 pm Sellesy do a suitable sealant you should be able to get easily. Here is a link http://www.selleys.com.au/sealants/sili ... k-concrete The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Caulking an expansion joint 3Jul 04, 2011 7:42 pm Im pretty sure ours is a Bostik product. Ill check.. Yep Colourseal Quote: Bostik Colour Seal is a strong, highly flexible (+/-20-25%), anti-fungal, mildew resistant acrylic gap filler. Colour Seal is designed for internal and external applications for horizontal and vertical sealing requirements where a flexible sealant is required. Colour Seal offers excellent adhesion properties when cured and is more flexible than conventional acrylic gap sealants with minimal shrinkage Available in: White, Beige, Light Grey, Dark Grey, Black, Coffee, Chocolate Brown, Terracotta, Deep Green. Custom European Cabinets - Melbourne Kitchen Specialist PM for business details as website currently being updated! Our Crazy Owner Builder Journey! Re: Caulking an expansion joint 4Jul 04, 2011 9:48 pm Another good one is Caulk in Colours Success is the result of good judgment, good judgment is the result of experience, and experience is often the result of bad judgment! Re: Caulking an expansion joint 5Jul 05, 2011 12:02 pm Thanks everyone. My main concern was that I would have to use some special high spec compound and that normal off the shelf products wouldn't be acceptable to the council inspector. Again, many thanks, Spike Re: Caulking an expansion joint 6Jul 05, 2011 12:34 pm The best caulking to use is ... get the builder to fix it! (My house uses Fuller's Caulk in Colours, but it could just as easily have been Shelleys No More Gaps Coloured Caulk. I chose what to use (based on the colour I wanted)) Demolition August 2009, Construction Started September 2009, Completed December 2010 To my understanding early saw cuts are to control shrinkage cracks, so doing them now would be pointless. Control joints may reduce ugly cracking during periods of soil… 3 9858 Hi all I need a guidance on how far I need to space expansion joints in the concrete driveway and its type (keyway/foam.) Contraction joints are at 3m max for a 125 slab. Thanks 0 10939 Hi, I am planning to select San Selmo reclaimed original for the fascade of my build. I have seen many photos on line of the brick varying from a rustic to a neat finish.… 0 4577 |
