Browse Forums General Discussion 1 Jun 19, 2011 2:22 pm Not having bought land yet, we are curious to know how much we should set aside for site costs. Please also indicate what major items (eg: root barriers, retaining walls, excavation etc) contributed to your site costs. Re: What were your site costs? Poll 2Jun 19, 2011 3:48 pm What state are you planning to build in? I built in West Victoria and had fixed site costs - roughly $9,000 Re: What were your site costs? Poll 3Jun 19, 2011 5:48 pm we're in melbourne. Will probably look for land in eastern established suburbs Re: What were your site costs? Poll 4Jun 19, 2011 6:49 pm This is kind of a pointless exercise in helping you determine how much to put away for site costs. People on here are from all over Australia and are building different size homes on different types of soil on different gradients using different building methods. Some will need retaining walls, some will have rock. You'll get answers from virtually nothing to close to 100k so not much of an indication for you. All sites are different so no-one can tell you how much to put away, you won't know that until you select your land and have it tested. Have a look at this thread.... compare to houses in roughly the same area or on the same soil type as what you'll building on, same house size and type (double or single storey) and same foundation technique e.g. slab. It will give you a much better rough guide than a poll. viewtopic.php?f=31&t=9017&hilit=ready+reckoner I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: What were your site costs? Poll 6Jun 19, 2011 7:35 pm There are so many differing factors which lead to site costs, and no 2 sites will be the same, even if they are next door to one another. Mine were $15.5K, sandy soils, no rocks, tree root barrier across the whole front of the slab, deepened edge beams along the garage wall were it was on fill. Raft slab construction for double storey. The land did slope from right to left and required 50cm cut and 50cm fill. Not much, but it adds up. No retaining walls done by builder, but we will put them in anyway. A friend of mine with the same builder in a nearby suburb is paying $55K, whereas someone a few streets away to them also with the same builder paid about $15K. You may find the perfect block which is flat, treeless, on non reactive soil and with no vegetation protection overlay and pay only about $10 - $15K, or you may not. The established Eastern suburbs of Melbourne are 'generally' hilly with lots of mature trees, so be prepared, then you won't get a shock!! Good luck!! Henley - Wilshire Mk 3 ... I love my house!! Site start: 4th Feb 09 Handover: 10th Sep 09 Blog: http://stormygirlscastle.blogspot.com/ Build Thread: viewtopic.php?t=7166 Re: What were your site costs? Poll 8Jul 11, 2011 11:28 am Site Classification: m class site Final Footing Design: Waffle slab House Size: 31 sq. including garage and decks Location: ferntree gully Wall Construction: Double storey Cut and Fill Requirements: Yes - there is a 3.9 m slope from back to front but not more than 1 mrr where the house will be built Retaining Wall Requirements: Yes Drainage Requirements: ? Special Requirements: ? Cost: 92000 Do you think is cost is realistic Re: What were your site costs? Poll 9Jul 11, 2011 11:50 am myhome83 Site Classification: m class site Final Footing Design: Waffle slab House Size: 31 sq. including garage and decks Location: ferntree gully Wall Construction: Double storey Cut and Fill Requirements: Yes - there is a 3.9 m slope from back to front but not more than 1 mrr where the house will be built Retaining Wall Requirements: Yes Drainage Requirements: ? Special Requirements: ? Cost: 92000 Do you think is cost is realistic You haven't given anywhere near enough information here to make a judgement one way or another. These details ... Cut and Fill Requirements: Yes - there is a 3.9 m slope from back to front but not more than 1 mrr where the house will be built Retaining Wall Requirements: Yes Drainage Requirements: ? Special Requirements: ? ... plus things such as rock removal, tree removal/barriers, site prep if there is a lot of existing spoil/vegetagtion to remove (topsoil needs to go before they can start with the site prep), etc. will determine the site costs in the long run, so just saying "yes" or "?" in response to whether these are needed is not sufficient - you need to quantify these things to get any reasonable sort of response from anyone. Some people apparently have nothing better to do than comment on other people's sigs. Re: What were your site costs? Poll 11Jul 11, 2011 3:01 pm $30,000 'P' class slab 2 x retaining walls (1.1mt high 5/6mts long ish) Excavation Building the Milano30 Site start: 30th June 2011 PCI: 1st December 2011 Handover: As soon as the bank pays! Approx 16th December viewtopic.php?f=31&t=44051 We hired Darbecca to do every stage inspection, and I strongly recommend them to anyone that asks me. They were amazing. Thorough reports with photos at every stage,… 6 7129 I am not sure whether Perth has its own way of doing things in regards to this. Most of Perth has class A (sandy soil), except for some areas near rivers or hills. 2 13098 Is anyone building with Mojo and have a recent site cost tender 0 15952 |
