Browse Forums General Discussion 1 Jun 12, 2011 8:23 am Hebel wall panel requires sealing against moisture and the Hebel booklet gives instructions for sealing the exposed surfaces. however no mention is made of sealing the base of the banel. Since the panel rests on a concrete plinth water is likely enter between the panel and the plinth and so wet the panel. A simple solution would be to treat the base of the panel with a water proofing agent. Does anyone have a comment about this? thankd I was looking at different options for a fence for my build and Hebel PowerFence seemed like a good option (one of the criteria was a solid wall look). However, I don't… 0 5906 1 6637 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6211 |
