Browse Forums General Discussion 1 May 14, 2011 9:45 pm Is the slab for your garage set down/lover than the rest of your house? Or is it the same? If it is the same, are you ok Happy with it? Re: Garage on the same level as the rest of your house 3May 14, 2011 9:58 pm I could be mistaken, but I actually thought it was a requirement that the garage was at a lower level than the house. I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: Garage on the same level as the rest of your house 4May 14, 2011 9:59 pm Hi Blue, my garage slab is set lower than the house slab. Not sure of actual measurements at the moment (can find out if you like) but there is one step up into the house from garage entrance door. Henley - Wilshire Mk 3 ... I love my house!! Site start: 4th Feb 09 Handover: 10th Sep 09 Blog: http://stormygirlscastle.blogspot.com/ Build Thread: viewtopic.php?t=7166 Re: Garage on the same level as the rest of your house 5May 14, 2011 10:00 pm your slab has already been poured hasn't it? 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: Garage on the same level as the rest of your house 7May 14, 2011 10:52 pm Thank you for your responses. Our slab had been poured and the garage is the same level as the rest of the house :s Re: Garage on the same level as the rest of your house 8May 14, 2011 11:07 pm blueblueblue Thank you for your responses. Our slab had been poured and the garage is the same level as the rest of the house :s oooh I don't know of the rules but mine is also a 'step' lower than the house - try to find the codes for your state to check. 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: Garage on the same level as the rest of your house 9May 14, 2011 11:15 pm blueblueblue Thank you for your responses. Our slab had been poured and the garage is the same level as the rest of the house :s Does the driveway slope noticably downwards in the direction away from the house? Cos I knew somebody who one time in heavy rain had water lapping at their door. Re: Garage on the same level as the rest of your house 10May 14, 2011 11:19 pm JazzyJess blueblueblue Thank you for your responses. Our slab had been poured and the garage is the same level as the rest of the house :s Does the driveway slope noticably downwards in the direction away from the house? Cos I knew somebody who one time in heavy rain had water lapping at their door. Yes it does ... But still. I hope I'm not the only one ... Re: Garage on the same level as the rest of your house 11May 14, 2011 11:26 pm Why don't you shoot onc a PM? He's the resident slab expert, I reckon he'll know whether it is ok or not. I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: Garage on the same level as the rest of your house 13May 15, 2011 9:53 am I thought it was a requirement for the garage to be lower too. Ours is 150mm lower than the house, so is the alfresco slab. As long as you're not at the bottom of a hill, you should be fine. Maybe some extra drainage across the entrance to the garage would be a good idea, just to be safe? Perhaps get some expert advice. Re: Garage on the same level as the rest of your house 15May 15, 2011 9:57 am Which state are you in, Mrs P? Re: Garage on the same level as the rest of your house 17May 15, 2011 11:36 am Ours is 5 courses lower, but we made it that way purposely. There are two large steps up to the house We've built 3 times and each time, the garage slab has been poured at a later date and doesn't form part of the house slab. Re: Garage on the same level as the rest of your house 18May 15, 2011 12:48 pm If your house is brick then the garage(& paths) will be -1C or 86mm lower( or 172mm for a 2 brick set down and multiples of 86mm = a brick course) Where you are coming from is where you are going to... This is one of the reasons I decided to go overseas for my double glazed windows. As the builder indicated, he's worked on many upmarket builds, these were the most well… 13 19076 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17414 they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo… 4 6578 |
