Quote for raising house and building underneath
Page 2 of 9
They suggested.
1) see a draftsman / architect to get plans drawn up
2) the drafstman will have a good idea of whether or not you will need town planning approval
3) if necessary (cross fingers that its' not) town planning approval may take many weeks and add $5K to process.. yuk.
4) lastly - submit draftsman's plans with engineers approval to Certifier. They will issue Council approval and building approval.
Does this sound correct?
Do any of you have renovation blogs, which we can have a look at???
Cheers,
Lotte
we just had the slab done, ended up with a bunker, blewout to $24200, won't fall down!
Currently sourcing quotes on building under using hardwood weatherboards, vj imitation sheeting etc. By the way we went with Budget House raising for the lift, these guys are very professional and did the job on time, no internal cracks! Good welding and all in all very pleased!
The house is reasonably sized for a post war (about 150m²), and with a bit of rejigging the interior, easily goes from being 2 bed + study with one bathroom, to 3 bed plus bathroom & ensuite. Also the living area is reasonable. We are more interested in just doing a big deck off the back and a reasonably big one to the front.
Have any of you guys restumped without raising?
Cheers,
Lotte
it costs bugger all difference to raise as against restumping (presume you'll replace stumps with galvanised SHS? the only extra costs are steel beams if required (to reduced number of posts and allow more room underneath) and the extra cost of the lengths of the steel posts which is only marginal. We had 43 posts including posts under a sizeable back decks and abouth 7 beams, we went up 1245mm at a total cost inc GST, bobcat/truck/excavator hire of around AU$29300. if your restumping definitely lift to at least legasl height (we went 2700mm) as then you always have the option of building under at some stage in the future. (PS you'll need plans done up if more than 20% of your posts need restumping anyway so may as well get all the renovations on the plan at the one time) Good luck!
Paul
I've got a guy coming on Monday to quote the restumping and I'll talk to him about raising the place. I just don't think the house would look right raised. It's L shaped - not your standard post war at all. I'll take some photos on the weekend and post them, so you can all see how ugly it currently is (and why I think raising may not be a good idea).
Cheers,
Lotte
Why can't you install brick piers or similar?
Matt
Following your post, I used Gary for the soil testing - great service although I did end up with a P classifaction due to a rotten hole over the future footings where a mago tree once stood.
I wish I could say the same for your certifier, useless they are.
And did you post some details on a cheap height serveyor? Want to post the details ?
You're right about houses springing up everywhere, one up the road was started and finished by a builder in what I remember was around 4 months and then there's one around the corner that is looking real similar to our design.
[Edit] .
We are in the southport area on the GC and about to embark on a similar journey, so it's been excellent reading.
Hope all has gone well.
I don't recall you making any mention of how the original house structure coped with being lifted and if you needed to repair much. Is there much stress placed on internal walls, flooring, roof etc?
cheers
just reread our post, we had surprisingly little damage after the lift, though I did happen to be there when one corner went up a tad quicker than the other 3 (the raisers use 4 x 30Ton Bottle jacks, thats it when raising) so there was a cracking noise at one point and I notice a hairline crack on the front fascia board which opened up a bit as the house was raised further, when the house was back on its 'legs' the crack closed (reminds me must putty that one, this will mean a pretty big ladder as its a long way up) we had a couple of hairline cracks in 2 windows but 1 or both may have already been there, there was no movement with the vj boards and all the windows and doors open the same, all in all a great job, prior to the lift you could feel movement in the house as you walked around as a couple of the posts were rotten/eaten by borers, now with the built in underneath the old girls as solid as a rock!, later wyld
At this point I have a million questions to ask having never undertaken any major renovation work - although I have worked on many commercial building renovations.
Do you mind if I shoot you a list of questions and see how you go answering as I'm sure there are others with similar.
1
The most likely cause of your timber swelling (parquetry?) is either a plumbing leak or carelessly leaving water on floors after use or both. Without seeing, i am ignoring…
15/12/2023
Currently renovating, and our main lounge is 5m x 10m, with a cathedral roof peaking at 6.5m high. Currently have tiles on concrete slab. Room is very hard to heat. I am…
8/11/2023
3
hey there! 😊 so, it’s kinda common for standard drawer depths to be around 500mm since most cabinets use this size to fit the usual runners…
