Browse Forums General Discussion 1 May 03, 2011 2:39 pm I'm creating a bar in my outdoor alfresco area and going for a "surf" theme. Bought a cheap surfboard off eBay and want to attach it to the outside of the house (brick veneer). What would be the best way to do this? Thanks Re: Attaching Surfboard to Brick 2May 03, 2011 3:59 pm Assuming its purely asthetical, I would cut the fins off, screw some pieces of timber to either end of the board, so you have some flat suface to work with. Then I'd dyna bolt a length of timber to the brick wall, and probably just liquid nails the 2 timber surfaces together. Alternatively you could screw in some hocks for it to rest on. Or, what might be cool would be to get some old roof racks, attach those to the wall and mount it on that. That would look cool. Re: Attaching Surfboard to Brick 4May 03, 2011 9:27 pm the_milesy Assuming its purely asthetical, I would cut the fins off, screw some pieces of timber to either end of the board, so you have some flat suface to work with. Then I'd dyna bolt a length of timber to the brick wall, and probably just liquid nails the 2 timber surfaces together. Alternatively you could screw in some hocks for it to rest on. Or, what might be cool would be to get some old roof racks, attach those to the wall and mount it on that. That would look cool. cut a few holes out aka plugs/ to where you are going to screw it onto the "backing board" then attach it to the board then fill the holes with the plugs invisible mouting solution.. use a really good adheasive and mount the SB onto a "mounting board" timber then cut into the SB to create the above "plug" then once dry.. drill holes into the timber then with assistance markt he holes onthe walls. then with dyna bolts install the Mounting board to the wall, then put in the plugs and coat with a clear drying adheasive. Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Attaching Surfboard to Brick 7May 05, 2011 8:52 pm Would luv a photo of the finished project sounds gnarly! 12th of Never land 20/3/07 ~~ Contract 17/11/10 ~~ Prestart 9/3/11 ~~ Footings 29/4/11 I plan on installing an undercover walkway (awning ??) from my carport to the back door as shown in sketch. I will be using Boxspan Beams and have no concerns regarding… 0 761 DIY, Home Maintenance & Repair Follow up question - any ideas on how to set up a portable air conditioner through this kind of window? 1 6236 2 8358 |
