Browse Forums General Discussion 1 May 01, 2011 12:42 am Just trying to decide on cornice and skirting. I quite like the stepped ones, but wonder whether they shrink the rooms? I dont want square set as I personally dont like it... Do you think the stepped cornice wsill look ok on a cathedral ceiling?? Re: cornice and skirting... 2May 01, 2011 9:04 am Depends a bit on the age / style of house. Do cathedral ceilings usually have cornices? I would consider trying to go without cornices and having a smooth / continuous look from ceiling to wall. If you do have a cornice, and you are wanting the cathedral ceiling to be the feature, I would have a simple cornice that blends into the background Re: cornice and skirting... 3May 01, 2011 2:00 pm chatterbox Just trying to decide on cornice and skirting. I quite like the stepped ones, but wonder whether they shrink the rooms? I dont want square set as I personally dont like it... Do you think the stepped cornice wsill look ok on a cathedral ceiling?? As long as the person doing the cornice work is competent, then the stepped cornice looks great - but I have seen some horror jobs where it doesn't line up properly etc. To keep costs down (cos the stepped cornicing is more expensive) consider putting the stepped cornice in the living areas and stick to standard cove cornice in bedrooms, laundry toilets etc. The photo is not really clear but to me it looks like twist in the cornice. Slight anticlockwise rotation at the top of the cornice and slightly clockwise at bottom should… 8 8474 Joe Apologies for the delay in getting back to you. If you haven't sorted this already you need to caulk this gap. Not sure where you are but if you are in Sydney I can… 5 4335 4 6008 |
